Dynoed Today.. Lost ~20whp and ~14 tq :( (BUT WHY?!)
Old Apr 9, 2008 | 04:14 PM
TylerC161's Avatar
Default Dynoed Today.. Lost ~20whp and ~14 tq :( (BUT WHY?!)
I have no clue as to why I've lost the power. I'm going to describe what I can right now since I dont have a copy of the dynograph, so please bare with me..
Modified by TylerC161 at 4:19 PM 5/15/2008
Old Apr 9, 2008 | 04:30 PM
A Blue Lude's Avatar
Default Re: Dynoed Today.. Lost ~20whp and ~14 tq :( (TylerC161)
If the motor compression tests ok I wouldn't completely freak out based on what you've described. That's a big difference though, and it is probably worth checking to see how healthy the motor is given that. Leakdown testing is also good, although a bit harder.
Old Apr 9, 2008 | 05:09 PM
98vtec's Avatar
moderator emeritus
same dyno?
does the graph look the same? same RPM peak torque? same peak rpm?
lean is bad. Lean = heat, excessive heat in time = damage
Old Apr 9, 2008 | 06:40 PM
TylerC161's Avatar
Same dyno, just months apart. Its not a PRECISE replica, but its an average of ups and down just above 20HP.
Leakdown and compression tests are going to be done next week.
Old Apr 10, 2008 | 12:38 AM
95greenlude's Avatar
Default Re: (TylerC161)
is it tuned? probably a source of another problem...DSM 450's on a stock p13
Old Apr 10, 2008 | 04:53 AM
mgags7's Avatar
DSM injectors suck to begin with, tuned or not.
The point here really is, does the car feel slower? You'd notice a 20hp loss across the board like you'd notice a hernia.
Old Apr 10, 2008 | 02:41 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
You'd notice a 20hp loss across the board like you'd notice a hernia.</TD></TR></TABLE>
^^^^^^For sure. More than likely the diffrence is in the dyno itself...
Old Apr 10, 2008 | 04:50 PM
TylerC161's Avatar
Default Re: (DCFIVER)
The dyno doesnt give anyone else problems, I dont see why it would me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">is it tuned? probably a source of another problem...DSM 450's on a stock p13 </TD></TR></TABLE>
Forgot to mention its all tuned on a p28. These numbers are the best we could do from tuning it. My baseline (running shitty) was like 130 something, ABSOLUTELY horrible
Old Apr 10, 2008 | 07:05 PM
98vtec's Avatar
moderator emeritus
does the car feel any different?
Old Apr 10, 2008 | 08:26 PM
TylerC161's Avatar
Default Re: (98vtec)
Honestly, its been running bad for like 2-3 months, I cant remember what it used to feel like. I put about 3-4 cars and still pulling on a f22 lude from a low roll if that means much.
Modified by TylerC161 at 11:07 AM 4/11/2008
Old Apr 11, 2008 | 10:09 AM
TylerC161's Avatar
up
Old Apr 11, 2008 | 10:20 AM
98vtec's Avatar
moderator emeritus
post a graph....
if a compression test and leak test come out normal, then there is nothing to worry about.
acura_b18c1
21
Oct 8, 2009 11:42 AM
r01516
Sep 11, 2008 02:48 PM
blackoutcivic
May 14, 2005 08:19 PM
shivic
May 19, 2002 07:16 PM
