passenger axle won't turn...
Old Apr 9, 2008 | 11:59 AM
nuggets's Avatar
Default passenger axle won't turn...
My buddy just put an obx lsd in his ys1 and now his passenger axle won't turn at all. Drivers side no problem. Any ideas? Autozone axles B16 with a ys1 cable tranny.
Old Apr 9, 2008 | 04:33 PM
1992Si's Avatar
Who installed the LSD ?
Oh I see, your buddy.
If the axle will not turn with the tranny in neutral. There has to be something wrong in the assembly of the LSD.
Did you test it before you installed the tranny ?
Old Apr 10, 2008 | 03:47 PM
khooper's Avatar
Default Re: passenger axle won't turn... (nuggets)
Get the CV joint looked at soon. If the CV joint breaks, you won't be driving at all.
Are you hearing some clicking sound? it is the symptoms of a damaged CV joint.
Most places replace the entire CV shaft as it is just as cheap (or sometimes cheaper) than attempting to repair the joint.
________________
OEM | DC HEADER
Old Apr 10, 2008 | 04:18 PM
1992Si's Avatar
Default Re: passenger axle won't turn... (khooper)
Oh I understand. You think the cv is broken.
OP check that?
He said it won't turn at all. I figured something in the diff is not right and locking the axle.
Old Apr 10, 2008 | 05:15 PM
schmiddr2's Avatar
Yeah it is very strange that the obx install and the non turning axle happened at the same time. I assume he never drove it after the install, but started it and put it in gear? Or did he find it not turning before while still jacked up. If the latter is the case, why didn't he just start the reverse process. Get the axle off and inspect it, rotate the other wheel and see if it turns the gear on the passenger side inside the trans. Process of elimination. gl
Old Apr 11, 2008 | 10:52 AM
nuggets's Avatar
Default Re: passenger axle won't turn... (schmiddr2)
the car doesn't have a running motor in it right now. He hasn't driven it at all. I suppose it's a good possibility the LSD is locked up because he installed it, and has never done a LSD install before.
EG civic
Apr 1, 2007 09:35 AM
eddiedeader
Dec 8, 2006 11:32 AM
Parker69
Oct 19, 2006 08:28 AM
Maxime
Sep 1, 2006 07:40 AM
longuyen88
Jun 16, 2006 09:41 PM
