What RPM for Longevity with H23 Vtec (stock)
I've read here in the forums and in the FAQ's that this swap my not be as reliable as the stock H23 or stock H22 because the H23 crank isn't made for the high rpms that the H22 ECU allows.
My Question:
What rpm should I set my redline to after the swap that will keep the H23 crank reliable and still get good vtec performance out of the head?
The engine internals are all stock, and it is a daily driver.
Thanks.
Modified by munky_350 at 11:00 AM 4/9/2008
My Question:
Thanks.
I've read alot of testimonials that sound GREAT but cant find someone who went from an H22Vtec to an H23Vtec. (most are all H23n/a swapped to H23Vtec)
I'd like to know that I'm not downgrading by any means and it wont make my prelude any slower than the current H22 Vtec I have now...or any less reliable to drive everyday.
Once I know that, it will be getting started asap.
I appreciate all your help.
Thanks.
Modified by munky_350 at 1:55 PM 4/9/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">How long do you want it to last?</TD></TR></TABLE>
ding ding ding.
if it was built properly (rotating assembly machine balanced) then shift it like an h22. If nothing was done to the rotating assembly, shift it lower for longevity. Between h22 redline and h23 redline.
ding ding ding.
Just my opinion but i have my H23 vtec redline set to 7500 with crosover at 4500. I have only taken it over 7k maybe 1-2 times but that was only because of traction issues and 2nd gear. Typically would shift no later than 6800 maybe 7000, not making power after that anyways so no real point in going past it especially if your stock.
PS, also just my opinion, but i dont see the point in going from a H22VTEC just to have a stock H23VTEC unless your H22 has problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUILT93ludeSi »</TD></TR><TR><TD CLASS="quote">Just my opinion but i have my H23 vtec redline set to 7500 with crosover at 4500. I have only taken it over 7k maybe 1-2 times but that was only because of traction issues and 2nd gear. Typically would shift no later than 6800 maybe 7000, not making power after that anyways so no real point in going past it especially if your stock.
PS, also just my opinion, but i dont see the point in going from a H22VTEC just to have a stock H23VTEC unless your H22 has problems. </TD></TR></TABLE>
Do you have vtec set arbitrarily or because that's what smoothed the engagement area? Seems a little low.
That's a crapload of midrange area you gained, crapload. I hope no one looks at this and sets their vtec that low without due reason though.
Btw, this the first I'm realizing the existence of the ECU Tuning forum.
Yes, My H22 has a knock and that is the . It's not a very loud knock but it is there, and will only get louder and eventually cause complete engine failure.
So instead of replacing the rods, bearings, crank, etc; and paying for a complete engine rebuild on top of that, I will just replace the entire block with an H23 block from a Prelude which the body was recently totaled but the engine and trans still run great and come out with alot less time and money in it.
unless anyone knows where to get rods, crank, bearings for under $500 (which is the cost of the donor Prelude)
