compression tester ?s
any recommendations on this before i go out and purchase one?
i dont have any experience with this, so i dont know if there are different types or things i should look out for. or are all the same? can anyone help?
thanks
thanks
Just recently bought one for about $29 plus change. It came with the adapter for long plug threads. It may not be 100% acurate, but the main thing you are looking for is not the PSI, it's the variation between cylinders. For casual use it's just fine. Just my $.02.
You can find them on ebay or at your local auto parts store. I would get a somewhat good one. Its not like its a leak down tester, a good one of those would cost some money.
Keith
Keith
Some of the ones out there only go up to 240-260, some go higher. Being someone with high compression, I would say look for a 300+ gauge. At 12.38:1 compression, I bottom the gauge out at 300 psi...
Jason
Jason
i found two so far that i am considering. they both have identical specs and features, the only difference being that the one from sears has a black face and the one from summitracing has a white face. both go up to 300, with the sears going for 24.99 and the summit on going for 21.99. i'll prob end up with the one from sears as i can go get it in one day and i wont have to pay s&h fees.
i think 300 should be more than enough on my sohc rite? i doubt i'll need a tester that read that hi
if anyone could recommend any other low priced brands that work well, feel free to let me kno
thanks again
thanks again
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
