how do you wrap harnesses around harness bar?
i'm having trouble wrapping my harnesses around my harness bar
my harness is similar to this:
and i read through threads..and i still don't know how to wrap it, since the metal piece that's supposed to bolt up to the c-pillar area or w/e is in the way..
am i supposed to cut the metal piece off or what? and sorry for being a noob..but i just want to do things right the first time around..without regrets ya know? thanks guys in advance
Looks like you bought the bolt in type. You need a wrap around harness. And please dont do the jdm x and bolt to the floor type of deal...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneSickJDMBB6 »</TD></TR><TR><TD CLASS="quote">
this was taken from schroth..i guess it's fine if you bolt it up to the floor w/o the use of a harness bar...</TD></TR></TABLE>
do you have a schroth harness? If not then don't mount like that, mount them how the manufacture says to mount them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
do you have a schroth harness? If not then don't mount like that, mount them how the manufacture says to mount them.</TD></TR></TABLE>
i have a sparco one. i'm probably just going to convert it to a 3-point and bolt it into the c-pillar area. sucks that i can't return my harness bar..but w/e. guess the harness bar is just going to look pretty in the car then.
i have a sparco one. i'm probably just going to convert it to a 3-point and bolt it into the c-pillar area. sucks that i can't return my harness bar..but w/e. guess the harness bar is just going to look pretty in the car then.</TD></TR></TABLE>
Mount it like sparco suggests.
If you don't, it will be dangerous and more harm then good.
the harness is designed to work mounted a specific way, if it isn't mounted that way it doesn't work.
i believe you can just replace the mounting bracket with the harness bar, assuming the mountaing bracket can be unlooped from the belt and the belt has a separate slide. I am in the sme situation as you and this is what I found.
http://www.hmsmotorsport.com/d...s.pdf
quote from page 37
"Racing harness with end brackets assembled to the shoulder belts by a 3-bar slide allow to dismount the brackets and use the 3-bar slide for wrap around installation directly to the roll cage. Also brackets can be exchanged e.g. from a snap-on to a bolt-in bracket or vice versa."
quote from page 37
the harness is designed to work mounted a specific way, if it isn't mounted that way it doesn't work.</TD></TR></TABLE>
QFT... much more harm than good will come of not mounting a harness IAW the manufacturers instructions.
EusebioSam19
Aug 20, 2009 02:01 PM
AWD: Jeff
Apr 12, 2006 05:35 PM
