uh oh throttle sticking
Old Apr 9, 2008 | 07:54 AM
llloyd's Avatar
Default uh oh throttle sticking
I have a sporadic problem with the throttle sticking open. Doesn't seem to happen when it is cold or even warm but when I run at high rev's for a while it doesn't want to let go. I can usually drop the revs by shifting but sometimes the revs climb again while the clutch is pressed. It is an aftermarket throttle body. It was doing it really bad at first and I had them replace the butterfly and I thought it was fixed but at the end of a 40 mile drive yesterday it started doing it again. Could it be the throttle cable?
I can't confidently say it wasn't doing it before the TB because I bought the car with a blown head gasket and obviously didn't run it hard until that was fixed at which point the TB went on.
94 civic si.
Old Apr 9, 2008 | 12:40 PM
Acidcrakker's Avatar
Default Re: uh oh throttle sticking (llloyd)
Clean out your TB AND Grease the throtal Spring.
Old Apr 10, 2008 | 09:56 AM
hurtgen's Avatar
check your floor mat. probbably not the case but it happened to me a couple times when i first bought my car. didnt know what the hell was going on. laughed at myself though when i figured it out.
Old Apr 10, 2008 | 10:26 AM
JoePSI's Avatar
Is this a Skunk2 TB?
https://honda-tech.com/zerothread?id=1566202
Old Apr 10, 2008 | 01:30 PM
llloyd's Avatar
Default Re: uh oh throttle sticking (Acidcrakker)
Stupid q, what kind of grease should I use?
I just cleaned it out with Seafoam Deep Creep this morning.
Definetly not the floormat, and its a Gude not a Skunk2.
Old Apr 15, 2008 | 12:36 PM
llloyd's Avatar
well the seafoam didn't work, had it sticking again today. what kind of grease should i use on the spring?
it happened really close to home so i pulled into my garage, popped the hood and just wiggled the throttle by the spring which felt really rough and then it went back to normal
jksmith
Feb 19, 2009 09:39 AM
shabam
Dec 9, 2007 07:52 PM
pohaku
Oct 1, 2007 01:04 PM
JDM H22
Sep 1, 2006 10:21 AM
burnrice
Sep 6, 2002 09:32 AM
