Injector Box (K-Series, 1000cc Peak and hold)
Old Apr 9, 2008 | 06:03 AM
done's Avatar
Default Injector Box (K-Series, 1000cc Peak and hold)
Is the Aem resistor box worth the upgrade over stock (old honda resistor box)?
Will it work with Kpro?
Thoughts?
MSRP: 349.99
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Peak & Hold Injector Driver Module* FAQs...
AEM’s external Peak & Hold Injector Driver module allows ECU’s that have a saturated injector drive circuit to trigger low impedance injectors with a true 4/1 Peak & Hold injector drive circuit.
AEM’s Peak & Hold Injector Driver contains 10 independent injector drive channels. Each channel supplies full battery voltage to a fuel injector for rapid current rise, in order to produce positive injector opening. When load current reaches 4.1A (amps), the injector driver reduces the load current to 1.1A and operates as a constant current source. This condition holds the injector open, and reduces system power dissipation. If the current fails to reach 4.1A within 5mS, the driver module automatically reduces the load current to 1.1A.
Installation is straightforward. Users simply hook the injector trigger wires from an ECU to the module, and then hook the output wires from the module to your injectors. Any number of channels can be used from one to 10.
*Legal in California only for racing vehicles which may never be used upon a highway.
For high-output racing engines that have exceeded the capacity of high-impedance injectors
Includes 10 independent injector drive channels for any engine up to V10
Complete wiring system included
Operating Voltage: 8-18 volts, negative ground
RPM Capability: Unlimited
Injector Triggers: 10
Trigger Waveform: Output is activated when input trigger is grounded
Trigger Impedance: 220 Ohm input impedance, pulled to 12V (60 mA draw)
Injector Outputs: 10
Output Current High: 4.15A Peak, Typical
Output Current Low: 1.15A Sustain, Typical
Peak Current Timeout: 5mS
Size: 5.5"L x 4.6"W x 1.4"H
Weight: 2.7 Lbs
Over Temperature Shutdown: 115C (Nominal)
Modified by done at 9:12 AM 4/9/2008
Old Apr 9, 2008 | 06:28 AM
done's Avatar
Default Re: Injector Box (done)
Also searching the forums came across this.
FJO Injector Box
MSRP: $190
The LOW IMPEDANCE INJECTOR DRIVER is built for the racing environment to withstand heat, vibration, dirt and water. It is designed to operate over the temperature range from -40 to +185 degrees Fahrenheit (-40 to +85 degrees Celsius).
Features
4 independent injector channels with input preloaded to 200 ohms
Allows use of low impedance injectors on ECUs designed for high impedance injectors only, no need to replace OEM ECU
Reproduces ECU injector pulses in PEAK & HOLD format (4A/1A)
Supports full sequential, phase sequential, and batch fired injector pulses
No special set-up required
Can be used in multiples for 6, 8, 10, and 12 cylinder applications
Benefits
Easy to install, installs between ECU and Injectors
Built for the racing environment to withstand heat, vibration, dirt and water
Free direct technical support
Modified by done at 9:43 AM 4/9/2008
Old Apr 9, 2008 | 07:31 AM
Mr.Blondie's Avatar
I contacted FJO a few weeks ago and they said that product is discontinued and sold out and that they are making a new one which should be comming out within a months time.
Old Apr 9, 2008 | 11:27 AM
SpoolnG2's Avatar
Default Re: (Mr.Blondie)
From what i've heard, the internals are exactly the same. The only difference is the number of injectors it can control. I'd go FJO
Old Apr 9, 2008 | 12:40 PM
mangina's Avatar
I just bought a FJO driver.
It was simple to wire up.
just waiting on my block to see if its wired right.
Old Apr 9, 2008 | 02:44 PM
ickyhonda's Avatar
Default Re: (mangina)
To answer the original question, yes it is a good idea. If you want more info on why, read the first paragraph in this thread. https://honda-tech.com/zerothread/2254427
turbod da
May 25, 2007 05:31 PM
Flava
Sep 25, 2006 08:20 AM
Justin Olson
Dec 14, 2005 11:06 PM
Mr.Death
Jan 30, 2005 08:23 AM
