eg hatch reverse lights don't work i tried everything!
Old Apr 9, 2008 | 05:13 AM
hondaon18's's Avatar
Default eg hatch reverse lights don't work i tried everything!
so my wifes eg reverse lights don't work when she puts it in reverse. and i changed the light bulds and replaced the fuses and still nothing. what else am i missing i looked to see if any wires that run to the hatch work spliced or disconnected but thier fine. where else can i look?
Old Apr 9, 2008 | 05:23 AM
slo_hatch's Avatar
Default Re: eg hatch reverse lights don't work i tried everything! (hondaon18's)
bump...i wanna know this answer too. one of my hatches did the same thing...im just curious on what caused it.
Old Apr 9, 2008 | 05:31 AM
ZenDynasty's Avatar
i know this sounds dumb but you did check to make sure the bulb is in correctly and are you blowing fuse repeatedly?
It happen to me once where the bulb was no incorrectly and I kept on blowing fuses, problem was corrected after I triple checked everything.
Old Apr 9, 2008 | 05:39 AM
egmatt93's Avatar
Default Re: (ZenDynasty)
was the car originally auto, is there a swap mor einfo plz... i know on my first hatch they didnt work because it was auto and i had to hardwire the wires in
Old Apr 9, 2008 | 05:42 AM
Default Re: (egmatt93)
yes the car is automatic and no im not blowing any fuses at all. and the light bulds are put right. i evened changed the light harness with my eg hatch harness and it does the same thing. only the brake lights turn on when i switch on the light but no reverse
Old Apr 9, 2008 | 05:50 AM
egmatt93's Avatar
Default Re: (hondaon18's)
bad ground?
Old Apr 9, 2008 | 06:56 AM
ground is fine check that already
Old Apr 9, 2008 | 08:57 AM
blk92_d16's Avatar
Well, on a manual trans there's a switch on the trans housing that depresses a "button" to activate the reverse lights. Not sure where or if the auto trans would have one...maybe under the shift console?
Old Apr 9, 2008 | 09:03 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (blk92_d16)
did you connect the reverse light switch properly? Did you use a manual harness? The manual engine harness has to interface with the automatic ECU/interior harness. Get a wiring diagram.
Old Apr 9, 2008 | 09:21 AM
philosofy1's Avatar
Default Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">did you connect the reverse light switch properly? Did you use a manual harness? The manual engine harness has to interface with the automatic ECU/interior harness. Get a wiring diagram.</TD></TR></TABLE>
it's not a swap, the car is still automatic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s &raquo;</TD></TR><TR><TD CLASS="quote">so my wifes eg reverse lights don't work when she puts it in reverse. and i changed the light bulds and replaced the fuses and still nothing. what else am i missing i looked to see if any wires that run to the hatch work spliced or disconnected but thier fine. where else can i look?</TD></TR></TABLE>
if the bulbs and fuse have been replaced and you've double checked them to make sure they are correct and correctly installed, then i would take a volyage meter and double check the wires. you want to make sure there are no breaks or shorts. not sure if the auto's have a reverse switch like manual trannies, but if so you might want to replace it.
Old Apr 9, 2008 | 09:24 AM
B serious's Avatar
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
It's not my fault I can't read.
Old Apr 9, 2008 | 09:26 AM
philosofy1's Avatar
It's not my fault I can't read.</TD></TR></TABLE>
LOL, it's cool man! happens to me all the time!
Old Apr 9, 2008 | 09:40 AM
yeah its automatic and it has always been. its driving me insane with this problem. is there anything else that i might be missing. with my self
Kid-jdm-teggy
Oct 15, 2015 07:27 AM
Freckles
Nov 20, 2011 10:10 AM
mini_eg_monster
10
Oct 26, 2011 04:54 PM
Psychoteen101
Aug 29, 2010 12:10 PM
