eg hatch reverse lights don't work i tried everything!
so my wifes eg reverse lights don't work when she puts it in reverse. and i changed the light bulds and replaced the fuses and still nothing. what else am i missing i looked to see if any wires that run to the hatch work spliced or disconnected but thier fine. where else can i look?
Re: eg hatch reverse lights don't work i tried everything! (hondaon18's)
bump...i wanna know this answer too. one of my hatches did the same thing...im just curious on what caused it.
i know this sounds dumb but you did check to make sure the bulb is in correctly and are you blowing fuse repeatedly?
It happen to me once where the bulb was no incorrectly and I kept on blowing fuses, problem was corrected after I triple checked everything.
Re: (ZenDynasty)
was the car originally auto, is there a swap mor einfo plz... i know on my first hatch they didnt work because it was auto and i had to hardwire the wires in
Re: (egmatt93)
yes the car is automatic and no im not blowing any fuses at all. and the light bulds are put right. i evened changed the light harness with my eg hatch harness and it does the same thing. only the brake lights turn on when i switch on the light but no reverse
Well, on a manual trans there's a switch on the trans housing that depresses a "button" to activate the reverse lights. Not sure where or if the auto trans would have one...maybe under the shift console?
Cool Cool Island Breezes. BOY-EE
Re: (blk92_d16)
did you connect the reverse light switch properly? Did you use a manual harness? The manual engine harness has to interface with the automatic ECU/interior harness. Get a wiring diagram.
Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">did you connect the reverse light switch properly? Did you use a manual harness? The manual engine harness has to interface with the automatic ECU/interior harness. Get a wiring diagram.</TD></TR></TABLE>
it's not a swap, the car is still automatic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaon18’s »</TD></TR><TR><TD CLASS="quote">so my wifes eg reverse lights don't work when she puts it in reverse. and i changed the light bulds and replaced the fuses and still nothing. what else am i missing i looked to see if any wires that run to the hatch work spliced or disconnected but thier fine. where else can i look?</TD></TR></TABLE>
if the bulbs and fuse have been replaced and you've double checked them to make sure they are correct and correctly installed, then i would take a volyage meter and double check the wires. you want to make sure there are no breaks or shorts. not sure if the auto's have a reverse switch like manual trannies, but if so you might want to replace it.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
It's not my fault I can't read.
Re: (B serious)
It's not my fault I can't read.</TD></TR></TABLE>
LOL, it's cool man! happens to me all the time!
Kid-jdm-teggy
10-15-2015 07:27 AM
mini_eg_monster
10
10-26-2011 04:54 PM
