LS with i/h/e, $200 to blow.
Old Jul 10, 2002 | 07:44 PM
civichbturbo's Avatar
Default LS with i/h/e, $200 to blow.
I have i/h/e on my car now.
I want to do another motor mod but
I am limited to $200.
I was thinking cams but its out of the question right
now because its not in my budget.
What do you guys suggest.
Old Jul 10, 2002 | 07:48 PM
Goy091's Avatar
Default Re: LS with i/h/e, $200 to blow. (civichbturbo)
save up and get some suspension done.
you could acutally get some springs w/the 200 dollars, but id just wait till you had shocks too, to install them.
Old Jul 10, 2002 | 07:51 PM
ridnmyhonda's Avatar
Default Re: LS with i/h/e, $200 to blow. (Goy091)
maybe some new cams...but that will be a lil more then 200 bucks
Old Jul 10, 2002 | 07:55 PM
Default Re: LS with i/h/e, $200 to blow. (ridnmyhonda)
I already have a full suspesion.
h&r/koni/rear sway bar.
$200 is my budget.
Old Jul 10, 2002 | 08:04 PM
tony4311's Avatar
high-flow cat
Old Jul 10, 2002 | 08:09 PM
punzak's Avatar
You really should probably save up some more. It would be financially beneficial. You would be saving labor at least, assuming that you have the "part" installed professionally. That said, maybe get some drag slicks for up front. I know someone selling Nitto 555R's for $175 a pair brand new. Also, if you plan to do some major mods in the future (ie. turbo, etc.) now might be the right time to upgrade your fuel or ignition components. Good luck! I hope I helped.
[Modified by punzak, 5:10 AM 7/11/2002]
Old Jul 10, 2002 | 08:36 PM
leechungsr's Avatar
how about a nice radiator cap and a polished battery tie?
Old Jul 10, 2002 | 09:00 PM
b18bfreak's Avatar
Get some cam gears and get
them dyno tuned.
Old Jul 10, 2002 | 09:07 PM
Big Teggie's Avatar
Default Re: LS with i/h/e, $200 to blow. (b18bfreak)
Cam gears and a fuel pressure regulator.
Old Jul 10, 2002 | 09:14 PM
StyleTEG's Avatar
Default Re: LS with i/h/e, $200 to blow. (tony4311)
high-flow cat
Exactly, $175 from http://www.ipsracing.com
It baffles me how many times I suggest this, yet no one seams to pick up. Your exhaust works as a system, not as individual peices. Header, Cat, Catback all work together. If one part is not performing well, the others will not perform well.
Right now your cat is a bottleneck. You have a nice freeflowing catback, but a small restricive cat header. Carsound cats flow almost as well as a testpipe, which will remove the 2" outlet bottleneck and poor stock flowability.
You no doubt spent over $1,000 on H/E, why short your gains by keeping a stock cat?
Old Jul 10, 2002 | 11:09 PM
nwarp's Avatar
Default Re: LS with i/h/e, $200 to blow. (StyleTEG)
dont spend anymore money on nick nacks that only gain you .00001 hp and save up for a vtec head
Old Jul 10, 2002 | 11:45 PM
B-Series Sol's Avatar
Default Re: LS with i/h/e, $200 to blow. (NA DC2)
but he already has IHE for the LS... so it makes no sense to recommend something like that. Also the LS-VTEC is tricky... ur probably not into that.
I suggest buying some cam gears... later get an SAFC and get the whole deal dyno tuned
Skunk2 Cam Gears - bout 200 bucks
APEXi SAFC - bout 300
Dyno Tuning - ??? 150
Old Jul 10, 2002 | 11:59 PM
island_son's Avatar
Default Re: LS with i/h/e, $200 to blow. (B-Series Sol)
How about a throttle body from inlinefour.com?
$225, it's a little over your buget. But it's a decent
upgrade for power.
Old Jul 11, 2002 | 06:29 AM
StyleTEG's Avatar
Default Re: LS with i/h/e, $200 to blow. (island_son)
Don't buy a bolton throttle body unless you know exactly what you are getting.
The different sizes greatly effect power, get one to big and you will gut your low and midrange for a little big of high power. All motor tegs do not want a large TB.
Complete your exhaust system first (again, highflow cat), then work on the intake path (intake, TB, intake manifold runner, cylinder head ports).
Old Jul 11, 2002 | 06:42 AM
gsr94's Avatar
tires!!
Old Jul 11, 2002 | 09:33 AM
Oh yeah! Forgot about the Intake Manifold... Skunk2 makes one for about 225 or so???
my friend got his from http://www.JDMhondaparts.com and the shipping was not that much.. none of our local shops could touch his price.
Throttle bodys are a tricky situation... i would hold off. Get thie Intake Mani first.
Old Jul 11, 2002 | 09:46 AM
slickboy's Avatar
New User
high-flow cat
I definately agree with you. You could go out and pick up a used intake manifold and work on porting/port matching it yourself. It will be good experience, and if you screw up, you're not out a whole lot of cash. Same thing with a throttle body.
Old Jul 11, 2002 | 11:07 AM
StyleTEG's Avatar
The IM is the same situation as a TB. The Skunk2 manifold is a replica of the ITR IM. For an all motor LS with only 140whp-150whp, it might have to large of a diamater for optimal low/mid range. I really don't know enough about the ITR/S2 IM to say its a good idea or not.
So an all motor integra wanting more flow velocity into the engine will like smaller cross sectional area at the cylinder head intake port and long intake manifold runners compared to a turbo version.
I agree with Slickboy that having a stock IM ported out slightly would probably be the best path unless you are planing on reaching 160-170whp all motor.
Happyman
Feb 11, 2003 11:08 PM
Ohlias
Sep 7, 2002 07:00 PM
Teg4e
Apr 30, 2002 05:15 PM
tweet20
Apr 9, 2002 03:04 PM
