disabling vtec for drag racer
Old Apr 8, 2008 | 06:26 PM
Charger69's Avatar
Default disabling vtec for drag racer
did anybody do this??? and is this effective? or would it hurt performance....since you dont want you car running the mild cam since your only dragging.....
Old Apr 8, 2008 | 06:46 PM
dmotoguy's Avatar
Default Re: disabling vtec for drag racer (Charger69)
toda had "vtec killer" cams.. they were hollow and probably made great peak numbers @ 10,000+ or something...
no real reason to lock your car on the vtec lobe though, probably more trouble than its worth.
Old Apr 9, 2008 | 05:15 AM
Charger69's Avatar
Default Re: disabling vtec for drag racer (dmotoguy)
aight yea....some guy at my track who runs an all motor crx disables his vtec mechanism and said the vtec takes away power/ time off the e/t
Old Apr 9, 2008 | 01:03 PM
Charger69's Avatar
bump?!?!
Old Apr 9, 2008 | 01:26 PM
Acidcrakker's Avatar
I dont believe you will hurt the motor by reving high without Vtec. If you want to see if there is a diffrence with out Vtec just unhook the Solenoid wire.
Old Apr 9, 2008 | 02:46 PM
antiJDM's Avatar
is this for real? lol.
Old Apr 9, 2008 | 04:19 PM
1992Si's Avatar
PM rota92
Brad locked Vtec open on our head last season. Ryan will get in touch with Brad at RLZ
Yes it will make more HP.
Old Apr 9, 2008 | 07:29 PM
si vtec ftw's Avatar
Default Re: disabling vtec for drag racer (1992Si)
vtec is designed to give the engine the fuel/air level it needs for low end power, and the higher amount in high rpm driving.
locking it IN vtec will hurt your low end torque, hondas wonderful downfall.
locking the motor in vtec, will make it run on a map thats not right, and its just al around no good far making power because it gives it that ideal motor, good mix a low, and good mix at high, thats the entire point.
wikipedia vtec and read up
Old Apr 9, 2008 | 08:19 PM
Neptronix's Avatar
Default Re: disabling vtec for drag racer (si vtec ftw)
word to that.
it is like the difference between having an open intake and a stock one with no other mods: low end torque goes to hell, high end gets a little peppier.
Not wise.
more intake restriction in the low-mid end is best for power. same goes for exhaust i believe.
Old Apr 10, 2008 | 02:48 AM
1992Si's Avatar
I think the last 2 posters missed the point this is a "drag race engine"
Who cares about low end power. The rpm's never get below 6500. rota was shifting at 9500.
Old Apr 10, 2008 | 04:19 AM
Legion's Avatar
* B A N N E D *
Default Re: (1992Si)
Are you talking about no vtec, or full-time vtec? This thread is confusing. Anyway, no vtec is definitely bad on a vtec head. Full-time vtec is great if you have vtec eliminating cams, because you can get rid of a ton of valvetrain mass (all the middle rockers and vtec pins) as well as the LMAs. This not only frees up more power but it makes the valvetrain more stable for high RPM revving.
Old Apr 10, 2008 | 07:21 AM
Charger69's Avatar
yea thank...god i still cant message anyone lol...but yea i have heard tht disabling it will help you out on the strip.....thanks alot
Old Apr 10, 2008 | 08:11 AM
1992Si's Avatar
I'll tell Ryan to check out this thread.
Do you want Brads phone # ?
Old Apr 10, 2008 | 08:44 AM
Charger69's Avatar
yea sure thatll be great!!! thank you
Old Apr 10, 2008 | 10:59 AM
Neptronix's Avatar
Lower your vtec point. Find out where vtec is beneficial for power gains and set it there.
requires more effort, but your quarter mile time will benefit from not losing torque/hp below 4000rpm.
Old Apr 11, 2008 | 09:24 PM
Default Re: (Neptronix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptronix &raquo;</TD></TR><TR><TD CLASS="quote">Lower your vtec point. Find out where vtec is beneficial for power gains and set it there.
requires more effort, but your quarter mile time will benefit from not losing torque/hp below 4000rpm.</TD></TR></TABLE>
HECDWS
Dec 25, 2004 10:26 AM
JDM00SI
Jul 18, 2004 11:06 PM
bluedelsol
Acura TL, RL & ZDX
Jun 6, 2003 07:09 PM
hooptie157
Apr 2, 2002 11:57 PM
crx(gator)
14
Feb 12, 2002 06:04 AM
