wierd overheating prob on 96 accord
Old Apr 8, 2008 | 06:14 PM
bseriescrxsi's Avatar
Default wierd overheating prob on 96 accord
i ran into this problem tonight...i was driving down the road and i came to stop and the car started spitting antifreeze....it was steaming out from under the hood, while it was steaming and dropping fluid onto the ground it was making a hissing noise....i made it to a place to let it cool down and add water.....after adding water i headed home..it didnt start steaming and hissing on the way home after i had added water...is there a pressure relif valve that may have just opened do to low collant levels?
Old Apr 8, 2008 | 07:22 PM
dleccord's Avatar
just change the thermostat if you havent already.
Old Apr 8, 2008 | 07:23 PM
Default Re: (dleccord)
i plan on doing so but i dont think thats the only problem as both the upper and lower rad hose were hot and the temp gauge was still working normal
Old Apr 8, 2008 | 07:29 PM
dleccord's Avatar
are there any sensors by the thermo?
Old Apr 8, 2008 | 07:34 PM
fan switch.....thats about all i can think of off the top of my head
Old Apr 8, 2008 | 08:00 PM
dleccord's Avatar
do you know exactly where is was leaking?
Old Apr 8, 2008 | 10:11 PM
that i dont...it was dark all i hear was a loud hissing sound and alot of steam....not exactly sure where it was leaking...im thinkin the radiator because of the hissing
Old Apr 8, 2008 | 10:15 PM
dleccord's Avatar
yeah let it blow off its load in the morning. its easier to find out the problem if you know where its leaking, or at least i think it will help others help you.
Old Apr 9, 2008 | 11:15 AM
fixed...the heater core hose going to the side of the engine went bad...thanks for helping dleccord
TheeInitiative
Mar 24, 2014 02:50 PM
faran
Aug 7, 2010 07:55 AM
oblivion2kx
Nov 10, 2008 08:27 AM
tonezilla
Oct 3, 2005 02:55 PM
rodvang
Sep 1, 2005 03:10 PM
