Stupid injectors!!!
Old Apr 8, 2008 | 05:53 PM
crispynuggets's Avatar
Default Stupid injectors!!!
Awhile back i had an issue with my H22 CRX and some injectors that i thought were staying open. I got new injectors and installed them, then tried to start it. It didnt start! I then heard something leaking!?!?!? sure enough it was the injrctors dumping gas, like as if they were stuck open! Im now thinking it could be a wiring issue!?!?! Has anyone had this same problem? could it be a faulty resistor box?
Old Apr 8, 2008 | 05:59 PM
Honda_Fanatic's Avatar
Default Re: Stupid injectors!!! (crispynuggets)
get an injector testing light (noid light) and see what it tells you. If the light stays on constantly it has to be wiring.
You can test the power coming out of the resistor box to see if that is the problem, but it seems unlikely. I personally have never heard of a box "going out".
Old Apr 8, 2008 | 06:27 PM
Default Re: Stupid injectors!!! (Honda_Fanatic)
ya im stumped i checked all of the injector wiring with a multimeter to see if maybe there is a mixe up in the wiring, maybe a crossed wire or something. all the injectors are in their respective places. I remember using my resistor box in a running vehicle a while back and it worked perfect. So i highly doubt that is the problem too. I'm just stuck and dont have a clue what the issue could be!!! Also the only injectors that are staying open are on cylinders 2 and 4.
nick91civicsi
Aug 21, 2006 05:15 PM
jeezerb18c
Sep 2, 2005 08:49 PM
AmauryR
Jul 23, 2004 10:28 AM
importfan2
Mar 14, 2003 12:00 PM
