what other maintenance do i have to do?
Old Apr 7, 2008 | 03:30 PM
dleccord's Avatar
Default what other maintenance do i have to do?
car specs: 1996 honda accord LX 2.2L non-vtec 4 dr 165,000miles
ive done: tranny fluid change, brake fluid change, rotors and pads change, rear drums shoes has about 80% left., just replaced outer tie rods.
those were done within the last 3 months. timing belt was replaced when i bought the car, which was at 118,000miles. i think coolant was changed about two months after that because of a leak somewhere. power steering fluid was never changed since i bought it. i havent done egr cleaning before, much less, on this car. upper ball joints arent ripped but the bottom one is.
what else do i got to do especially at this mileage? what do most people replace and what other fluids should i look at?
thanks.
Old Apr 7, 2008 | 07:58 PM
dleccord's Avatar
bizzump
Old Apr 7, 2008 | 09:11 PM
SOHCMAN's Avatar
Default Re: (dleccord)
Definitely clean the EGR ports, and I dont think you mentioned changing the clutch fluid (to get moisture out) and the engine oil ... maybe have the AC professionally drained and filled? The fuel filter should be change also...
Also your sway bar rubber might be on its way out. If you don't know how old the headlights are it never hurts to go ahead and swap em out.
Other than that, drive it. Should be a good car for many miles...
SOHC
Old Apr 7, 2008 | 09:55 PM
dleccord's Avatar
i didnt know LX comes with sway bar? or am i thinkin about the stabilizer bar that comes with EX?
i have an auto so no need to bleed the clutch.
oil change is every 3k so im not worried about that.
EGR! i might have to look into this; but do i have to remove the fuel rails and i dont have to drill the holes for my generation correct?
Old Apr 7, 2008 | 11:26 PM
Honda_Accord's Avatar
no you dont gotta drill holes, as soon as you lift the plate up you will see the holes, they will either be clear or have build up, there is a write up in the accord faq
Old Apr 7, 2008 | 11:35 PM
dleccord's Avatar
alrite but will there be any steps that gasoline will leak?
any special tools required?
oh and carb cleaner should be used to clear the egr ports?
Old Apr 8, 2008 | 03:45 AM
TouringAccord's Avatar
H-T Order of Merit
I don't recall the exact procedure off the top of my head but since you will be removing the fuel rail to gain access to the EGR plate, yes, there is a chance you'll leak some fuel out. Just have towels ready to catch the mess.
no special tools required that I can think off.
It would probably be best to try and pick most of the deposits out of the holes rather than flushing them into the intake ports. But a really good cleaner that I've used on other things is Berryman's B12, you can get it at most part stores and the stuff works great on carbon deposits and things like that.
Old Apr 8, 2008 | 07:29 AM
dleccord's Avatar
and Berryman's B12 would be in the carb cleaner section?
Old Apr 8, 2008 | 07:36 AM
H-T Order of Merit
yes
Old Apr 8, 2008 | 08:00 PM
dleccord's Avatar
and basically i would want to shoot the gunk back into the intake manifold? what if i cant pick it out?
kramun
Mar 17, 2014 08:59 PM
RolandDeschain
Honda Civic (2001 - 2005)
Sep 6, 2011 10:51 AM
morris029
Sep 28, 2010 04:15 PM
Ms.JDMdb8
Jul 9, 2005 06:34 AM
uNF$@#!
Mar 1, 2003 08:10 PM
