Has anyone tried this with a d15b?!?!?
Old Apr 7, 2008 | 12:55 PM
twentytwocpb's Avatar
Default Has anyone tried this with a d15b?!?!?
D15b with a p28 computer non-chipped. If so, how was it? or how was the reaction between the engine and computer? or
Old Apr 7, 2008 | 02:01 PM
Relic1's Avatar
WHICH d15b?
there are at least 3 of them.
if you're talking the standard 130hp VTEC version then it will run a little rich (1.6L ECU on 1.5L engine) and the ignition maps will be slightly off. But it will run ok.
If you have the VTEC-E or the non-VTEC version then it will run like crap at best.
(there's also a two VTEC solenoid version that came later)
Old Apr 7, 2008 | 02:20 PM
Default Re: (Relic1)
lol yea im planning on dropping in a JDM d15b. I have a d16z6 now...so my computer is mapped out to run that. Old engine so i wanna replace. What can i expect tho if i do DO the swap. Like starting, running, idling. Will it have any effects becuz of the computer im using(p28)?
Old Apr 22, 2008 | 07:11 PM
vtec17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">WHICH d15b?
(there's also a two VTEC solenoid version that came later)</TD></TR></TABLE>
Not completely true. Am running a p28 on a non-vtec d15b and my car runs fine. Idles at about 800 rpm and redlines at 8,000 rpm I don't make power after 7,500 roughly maybe a little sooner but I can and have taken it to 8k many times just for fun. Does run a little rich though. Am about to swap a v tec head on it so we will see how that goes.
Old Apr 22, 2008 | 07:16 PM
z6hatchboy's Avatar
Default Re: (twentytwocpb)
The effects of the p28 wont be great enough to hinder starting, idleing and such. You probably just wont get as good mpg as you would chipping it, and it will be a hair off in performance compared to chipping your ecu.
Old Apr 22, 2008 | 07:50 PM
2000siturboR's Avatar
Default Re: (vtec17)
you have a single slam 1.5 non vtec that can rev out to 8 grand. i highly doubt that. not so much that can rev it out sure fact you wont snap a rod or bend a valve
Old Apr 22, 2008 | 07:58 PM
wtfmate3487's Avatar
I had an EG with a JDM D15b vtec and a p28 not chipped.
It ran fine, like everybody has said, it was rich. It started and ran really good actually. Why not just keep the z6 though? mileage?
Old Apr 23, 2008 | 12:35 PM
Default Re: (wtfmate3487)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtfmate3487 &raquo;</TD></TR><TR><TD CLASS="quote">I had an EG with a JDM D15b vtec and a p28 not chipped.
It ran fine, like everybody has said, it was rich. It started and ran really good actually. Why not just keep the z6 though? mileage?</TD></TR></TABLE>
yea mileage is up almost to 200,000
Old Apr 23, 2008 | 04:01 PM
vtec17's Avatar
Default Re: (2000siturboR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000siturboR &raquo;</TD></TR><TR><TD CLASS="quote">you have a single slam 1.5 non vtec that can rev out to 8 grand. i highly doubt that. not so much that can rev it out sure fact you wont snap a rod or bend a valve</TD></TR></TABLE>
I don't blame you for not Believing, I probably wouldn't believe it either if I wasn't the one doing it myself. People get shocked when I show them. At first I thought my tach was just wrong but I installed an auto meter tach also just to see if my stock tach was wrong but they both hit 8k. Been running fine for about 7 months now.
Old Apr 23, 2008 | 07:52 PM
95vxtealhatch's Avatar
I just did this swap. I have a d15b with a z6 head. I used the p28 5spd ecu. To be perfectly honest, this combo lacked alot of midrange power. It had power from idle to 2.5k then had power a 6k till redline. It ran just fine, but the mileage was terrible. It must have been getting like 20-25 mpg. The solution to my problem was getting my ecu tuned on crome. It runs great and i get great milage now.
Empirecivic91
Dec 2, 2009 10:48 PM
javon972
Jul 13, 2008 12:17 PM
JUN.
13
Oct 10, 2006 11:48 AM
ef9i@asia.com
Jun 25, 2006 06:33 PM
Slammd Sol
Mar 24, 2004 07:45 PM
