ECU resetting
Old Jul 10, 2002 | 04:53 PM
go_noles28's Avatar
Default ECU resetting
I gotta 96 LX with CAI, Header, APEXi exhaust, I shouldn't need to mess with the ECU at all to notice any gains should I?
Old Jul 10, 2002 | 05:24 PM
Gennady's Avatar
New User
Default Re: ECU resetting (go_noles28)
Reset the biatch. Its real easy. Pull off negative termal, pull ECU fuse, pull Hazard fuse for 10 minutes. Apply brakes a couple of time to get all the left over electrons out. Put everthing back after 10 minutes and let the car idle for 10 minutes.
Old Jul 10, 2002 | 05:41 PM
go_noles28's Avatar
Default Re: ECU resetting (Wont be beat)
Will that make any difference though? When I put all of the aftermarkets on I was very disapointed in the lack of performance gain noticeability! Will that change anything?
Old Jul 10, 2002 | 07:46 PM
Gennady's Avatar
New User
It might make it a little smoother. But most likely wont add any hp. Welcome to the minescule world of bolt ons.
Old Jul 10, 2002 | 09:09 PM
96 SOHC VTEC's Avatar
You have an Accord. Putting all these bolt-ons isn't going to be a HUGE gain. It's a heavy car. I don't even think I noticed my intake on my Civic and it gave my about 7hp at the flywheel on the dyno. My friend had a lot done to his old Accord and it wasn't that much faster than his brothers stock one of the same year. However, you go dyno that car, and I'm sure you will notice the gains. Either way, reset your ECU. It should help out a little.
Old Jul 11, 2002 | 06:08 AM
Gennady's Avatar
New User
Default Re: ECU resetting (96 SOHC VTEC)
A dyno does not measure flywheel horsepower.
Old Jul 11, 2002 | 09:50 AM
Whoops. I meant to say at the wheels.
[Modified by 96 SOHC VTEC, 6:51 PM 7/11/2002]
Old Jul 11, 2002 | 09:57 AM
KTeller8's Avatar
Oo
Old Jul 11, 2002 | 10:03 AM
Brandon's Avatar
Life is Suffering
Default Re: ECU resetting (KTeller8)
The reason you want to reset the ECU is to allow the computer to "start fresh" with its new state of tuning. This way you can take advantage of all the power you gained by having a more even fuel mixture and a smoother power curve. These things seem trivial, but you will appreciate them.
Old Jul 11, 2002 | 03:25 PM
Razor's Avatar
Default Re: ECU resetting (accordvtec)
i think you need to warm up the car to normal operating temps before taking off the negative on the battery or taking out the ecu/efi fuse.
does anyone have EXACT CORRECT directions? i dont these halfassed directions
Old Jul 12, 2002 | 06:13 AM
jweller's Avatar
Default Re: ECU resetting (Razor)
At least on 6th gens. all you have to do is pull the fuse labeled clock, backup. it's number 13 on the passenger side, and leave it out for about 10 seconds. that is from the Helms manual, so I'm sure it's right. teh ECU pulls a small ammount of current from the battery to hold memory. don't know about the 5th gens but I imagine it is a similar procedure
Old Jul 12, 2002 | 06:29 AM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default Re: ECU resetting (jweller)
Is this for the V6's too?
Old Jul 12, 2002 | 05:24 PM
go_noles28's Avatar
Default Re: ECU resetting (sleeperaccordv6)
Thanks alot guys. I appreciate your explanations. You were a great help.
Old Aug 25, 2002 | 02:31 AM
RC211V's Avatar
but then again it depends on what kinda dyno. if he reset the ecu and pulled the motor out to dyno the sucka man you got probs.
Old Aug 25, 2002 | 01:38 PM
greensleeper's Avatar
Not sure on the proper procedue to reset ECU. But pulling more fuses than less islikely to work.
Don't forget this... its the most important part.
Old Aug 25, 2002 | 02:30 PM
niedejb's Avatar
Default Re: ECU resetting (greensleeper)
Dont know what its worth but my borther (97 prelude) was going to reset his ecu before dynoing (hadnt done it since ANY of his mods) and forgot.
On the fourth or fifth pull he remembered. We kept everything the same pulled the negate off the battery for >5min. Dynoed again.
NO CHANGE. I was surprised after all I had heard.
Old Aug 25, 2002 | 05:24 PM
Default Re: ECU resetting (niedejb)
I don't think 5 minutes is enough. Most people tell me that 30 minutes is the minimum.
This is like some sort of Honda Myth. Everyone talks about it but no one knows for sure. I'm gonna check with my Honda buddy.
Old Aug 25, 2002 | 06:18 PM
niedejb's Avatar
Its not time dependant. Its either all or nothing. Pulling the battery leaves the ecu with nothing. Its not like a PC or like a vafc that has a internal battery or eproms repectively. One minute would do it.
The resetting does nothing.
Old Aug 25, 2002 | 06:24 PM
H23 Power's Avatar
when you dyno its at WOT which is open loop mode so there's really no way that the ecu would "learn" anything...
does it learn at part throttle? yes...but does resetting the ecu help? who knows
Old Aug 25, 2002 | 06:28 PM
Brandon's Avatar
Life is Suffering
Default Re: ECU resetting (F23 Power)
It helps for the car to run more smoothly. My idle roughness is a thing of the past now.
jimmysxxl
K Series
Oct 1, 2013 11:12 AM
HondaHelpPlz
Dec 13, 2009 07:15 PM
HONDAVTIS
Jan 23, 2007 03:16 AM
cp_harrington
Jan 20, 2003 08:35 PM
Turbo Powa
11
Jun 2, 2002 09:20 AM
