Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
a reminder re: timing belt covers
Old Apr 7, 2008 | 09:21 AM
R you serious's Avatar
Default a reminder re: timing belt covers
use them- they work
tiny rock somehow flew up in cam gears and jumps lots of teeth on the timing belt-lots of piston to valve contact
motor had 20 minutes on it-
happened in qualifying-
note: b16b motor was swapped out to b16a bottom end-
timing cover wouldnt fit on the b16 head because of the deck height dif. in the motors.
Old Apr 7, 2008 | 09:24 AM
navin's Avatar
Default Re: a reminder re: timing belt covers (R you serious)
that sucks. I've been running w/o the upper timing cover for like 4-5 track events, but luckily no damage. But I'm def. ordering one before the next event. Also, locktite those bolts for the cover!
Old Apr 7, 2008 | 09:40 AM
Timmah!!'s Avatar
The upper on my CRX hasent been on in 3 years... :X
Old Apr 7, 2008 | 10:29 AM
Mr.OB*GYN_Rhett's Avatar
Jeff, we have a basically complete B16a2 bottom end...
Old Apr 7, 2008 | 11:27 AM
Default Re: a reminder re: timing belt covers (Mr.OB*GYN_Rhett)
its not the bottom end that concerns me- -
ill get the headoff this week and pray for just a couple bent valves-
Old Apr 7, 2008 | 12:04 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">use them- they work
How do you know it was a rock that caused the belt to jump?
Old Apr 7, 2008 | 01:00 PM
Default Re: a reminder re: timing belt covers (Chris F)
only think i can think of -
there is no grass around the track- only gravel-
tension was still tight and the belt as well.
had to have been a small rock or tire goober
Old Apr 7, 2008 | 02:01 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">only think i can think of -
had to have been a small rock or tire goober </TD></TR></TABLE>
Well, if the motor only had 20 minutes on it, I'd have guessed something else caused it. Occam's Razor and ****. I could totally be wrong though. That sucks either way!
-Chris
Old Apr 7, 2008 | 06:00 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
How do you know it was a rock that caused the belt to jump?</TD></TR></TABLE>
That's what I was going to say as well. Innocent until proven guilty!! I highly doubt it was a rock, especially on a new motor.
Old Apr 8, 2008 | 08:01 AM
FlyZlow's Avatar
Default Re: a reminder re: timing belt covers (sporkcrx)
FWIW - there were a ton of rocks flying around that track, so I think it could be a valid theory. I saw several broken windshields and one of the H2 cars even got a rock lodged in his rear caliper somehow and it made the most god-awful noise you have ever heard as it scraped along the rotor. Plus, the paddock was basically just a gravel surface, so even driving around the paddock you were constantly kicking up rocks. Not saying that it definitely caused the failure, but I think it's more plausible than you guys are thinking.
Old Apr 8, 2008 | 08:05 AM
spun Vtec's Avatar
-Chris
x2 If it were a rock I bet there would be damage to the belt.
Old Apr 8, 2008 | 08:16 AM
rock is the only thing i can think of, as the tensioner was still tight and so was belt-
ill know when i pull off the lower cover- i hope there is a small rock in there- if not its a mystery-
Old Apr 8, 2008 | 11:17 AM
1net's Avatar
Well if you don't find one, see if the camshafts actually rotate. It took me 20 minutes this one occasion to find out that a cam has seized in the head (bad head to cam clearances). I really hope that a simple stone is the case.
924doorEG
12
Sep 6, 2007 07:44 AM
B16b-EJ8
Mar 1, 2007 09:02 AM
93hondaprelude
Jan 31, 2006 01:12 PM
foam
Dec 26, 2005 10:23 AM
JohnnysEG
Aug 7, 2005 10:52 AM
