40MM tial wastegate ok for my setup???
Old Apr 7, 2008 | 08:14 AM
KillAHonDa's Avatar
Default 40MM tial wastegate ok for my setup???
hey all , just wondering if the 40mm wastgate is ok for me to use - ls-vtec fully built w/ a gt35r turbo - power goal is 600whp.. thanks
Old Apr 7, 2008 | 08:24 AM
RCautoworks's Avatar
Default Re: 40MM tial wastegate ok for my setup??? (KillAHonDa)
Why wouldn't
Old Apr 7, 2008 | 08:37 AM
KillAHonDa's Avatar
Default Re: 40MM tial wastegate ok for my setup??? (RCautoworks)
thats why im asking .. its my first turbo build , and im still kinda noobish ..lol
Old Apr 7, 2008 | 08:39 AM
It should be ok.
Old Apr 7, 2008 | 08:42 AM
KillAHonDa's Avatar
thanks
Old Apr 7, 2008 | 10:08 AM
SpoolnG2's Avatar
What manifold do you plan on using? Are you gonna run a boost by gear boost controller? Whats the lowest boost you plain on running? Personally with my experiences I dont think the 40mm will be enough.
Old Apr 7, 2008 | 10:25 AM
KillAHonDa's Avatar
Default Re: 40MM tial wastegate ok for my setup??? (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">What manifold do you plan on using? Are you gonna run a boost by gear boost controller? Whats the lowest boost you plain on running? Personally with my experiences I dont think the 40mm will be enough.</TD></TR></TABLE> I plan on running a Full Race ramhorn mani , no boost by gear, and lowest psi is prolly around 12-15lbs
Old Apr 7, 2008 | 10:36 AM
SpoolnG2's Avatar
I would atleast run a 44mm....its a big turbo on lower boost with a very efficient manifold. I used to run a full-race ramhorn with a t3 sc61 and a 44mm wastegate and still had boost creep. I had a 12psi spring and it would creep to 17-18psi. Now i believe they redesigned their manifold as far as how the wastegate is situated so it might be better now. But I atleast figured i'd throw out my experience to you. With my current setup I said right off the bat i'm not dealing with any boost creep, so I went right with a 60mm. I know its overkill and huge but I know for a fact it will hold boost as low as I choose to go with those larger turbos. Just my .02
Old Apr 7, 2008 | 10:59 AM
KillAHonDa's Avatar
my original plans were to go with a 44mm but my friend is selling his Full race mani to me (40mm) for 500.00 so i wanted to take advantage of a good price for a very good product. would u recommend buing that mani and have it re-flanged to a 44mm? if so should it go directly to Full Race or can any shop re-flange it?
Old Apr 7, 2008 | 11:43 AM
SpoolnG2's Avatar
yeah id atleast send it back to have it reflanged for a 44mm gate...id send it back to FR since its their mani originally.
Old Apr 7, 2008 | 06:42 PM
DLO01's Avatar
As stated above. On that size turbo with that good flowing manifold and that low boost. I would go larger than a 40mm if you want to have full boost control.
Old Apr 8, 2008 | 06:20 AM
KillAHonDa's Avatar
Default Re: (DLO01)
THANKS FOR THE ADVISE GUYS!
karmadhi
Oct 1, 2011 04:12 PM
iNERtIA
Jun 18, 2007 04:50 AM
ilikebigbutts
Dec 20, 2006 05:46 PM
JDM_EH2
Dec 24, 2005 06:04 AM
slooogsr
Oct 26, 2003 01:36 PM
