Which oil for a motor that has......
Old Jul 10, 2002 | 04:04 PM
hondacivic4g's Avatar
Default Which oil for a motor that has......
I did a search and this is a very debateable topic.
I want a good oil that is going to help my engine run well and protect it.
It's an 89 SI with 220,000+ miles on it.
So to start which should i use conventional or synnthetic?
Next which weight 10w30 or 5w30?
Finally which brand Moble1, Castrol, Valvoline or what?
Thanks-HC4G
Old Jul 10, 2002 | 04:19 PM
the DR.'s Avatar
Default Re: Which oil for a motor that has...... (hondacivic4g)
i think you should use 10w30 conventional oil, if you run synthetic on an older engine, itll probably leak bad... if you want to keep if ur engine running well just make sure u do regular maintanece on it
Old Jul 10, 2002 | 04:52 PM
rickshank's Avatar
New User
Default Re: Which oil for a motor that has...... (CIVICtypeS)
My 89 SI hatch has 287,xxx miles on it. Original motor, original head, original bearings, yada yada. Changed the head gasket though. I run 10w30 all the time, and I'm not picky about the type. Regular old dino oil, none of that synthetic stuff for an engine with that loose of bearings I make sure to change the oil before 3,000 miles hits. All that's done with the car is autocrossing, and it's holding up pretty well. No clouds of smoke or anything.
5w30 is too thin for it. 10w40 isn't such a bad option either.
~Ricky Shank
85 CRX SI - e-prepared #86
89 Civic SI - c-street prepared
02 Civic EX
Old Jul 10, 2002 | 08:14 PM
rioninja's Avatar
Look into Valvoline MaxLife. The actual makeup of the oil is supposed to be very good.
And definatly 10-30 or 10-40. 5-30 is way too thin.
Old Jul 10, 2002 | 08:46 PM
USDM 4G VTEC's Avatar
Default Re: Which oil for a motor that has...... (RioNinja)
word up on that
ill go with Valvoline Max Life 10w-30
its better.. dont go syntetic or u might screw something up....
stay with that and keep an eye on the car.....
u might wanna add a Slick 50 additive or Z max or something....
Old Jul 10, 2002 | 11:41 PM
DJ KrunchyKracker's Avatar
i got 128,xxx on mine. only needs a valve cover gasket. change the oil every 2000 mi and everything is fine. i use havoline. that oil has always done me good. 10w-40 for the summer and 10w-30 for the winter. when i change it usually comes out about as clean as it went in.
Old Jul 10, 2002 | 11:58 PM
osideracer's Avatar
Default Re: Which oil for a motor that has...... (TheRZA28)
<FONT COLOR="green"> so when is a good time to use synthetic? on new cars or race cars? i used to use synthetic on my old car, never knew i could harm it that way.</FONT>
Old Jul 11, 2002 | 07:34 AM
Chris_'s Avatar
Default Re: Which oil for a motor that has...... (JDM EF9)
oil additives will kill your motor....
I lost a 4 door EF to that ****
Old Jul 11, 2002 | 07:37 AM
Default Re: Which oil for a motor that has...... (crxconnection)
sorry man
i always used slick 50 sutff and always got good results... low water temperatures. smooth reving, oil not that dirty....oil temp normal, and oil poressure normal too.,... maybe u had an extra factor help u mesed that engine out.. who knows....
Old Jul 11, 2002 | 10:14 AM
Steve91's Avatar
Any name brand oil will be fine, just change it regularly. I would run 20/50 is hot weather and 10/40 in cold. Usually on high mileage motors, all the tolerances are loosend way up and thinner oil will burn too easily.
Highpower
11
Oct 16, 2019 03:53 AM
saemoonyang
12
Oct 16, 2011 05:53 PM
Poey2
Jan 27, 2010 04:16 PM
crxhybrid1320
Feb 7, 2003 05:22 PM
HybridCoupe
Feb 3, 2003 08:53 PM
