quick ls and gsr block question
Old Apr 6, 2008 | 05:44 PM
fatpride111's Avatar
Default quick ls and gsr block question
whats the main difference between the blocks? i blew my piston rings, and need to redeck, and rehone my gsr block, aswell, as buy new bareing and whatnot... which will cost me an *** load of $.
i found a newly honed, and decked b18a1 block fairly cheap, and was wondering what the main difference was between the blocks if any.
i plan on dropping in an ls crank if i keep my gsr block, so im basicaly just wondering about the shortblock. durability differences? etc.
TIA!
Old Apr 6, 2008 | 05:56 PM
RyanA's Avatar
Default Re: quick ls and gsr block question (fatpride111)
Block wise, GSR has VTEC oil feed and squirters. However, if you are going to run an LS crank, you no longer need squirters since the LS rods have squirters located in the tops of the big ends of them anyway. GSR block has girdle on center 3 mains, LS block does not. Otherwise, deck height is just a tiny bit different.
Old Apr 6, 2008 | 06:55 PM
Default Re: quick ls and gsr block question (RyanA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanA &raquo;</TD></TR><TR><TD CLASS="quote">Block wise, GSR has VTEC oil feed and squirters. However, if you are going to run an LS crank, you no longer need squirters since the LS rods have squirters located in the tops of the big ends of them anyway. GSR block has girdle on center 3 mains, LS block does not. Otherwise, deck height is just a tiny bit different. </TD></TR></TABLE>
so it really wont make a difference? would the deck height make a difference in C/R if we use the ls crank, gsr rods and pistons in both blocks?
Old Apr 10, 2008 | 06:08 AM
RyanA's Avatar
Rule of thumb is to use the rods that match the crank. IE: LS crank to LS rods, GSR crank to GSR rods.
Ryan
russianswty
Oct 17, 2006 03:09 PM
faSHOwidIT
Aug 2, 2006 04:40 AM
marcussmith26
Dec 5, 2005 05:28 PM
typeRSXS
Mar 24, 2004 03:54 PM
