Attaching a K&N to stock intake pipe(pict request)?
Old Apr 6, 2008 | 03:15 PM
lsturbo*'s Avatar
Default Attaching a K&N to stock intake pipe(pict request)?
Finishing up my build and need a quick, simple, cheap intake. I just want to use the stock pipe to the manifold, and put a K&N on the end. Only issue is how to attach the filter, I need some kind of coupling and some clamps. I would appreciate any picts/or part #'s /advice. Here is a pict of the pipe I want to use:
Old Apr 6, 2008 | 03:36 PM
gsilnc's Avatar
Default Re: Attaching a K&N to stock intake pipe(pict request)? (lsturbo*)
not k&n but it gets the job done
Old Apr 6, 2008 | 04:02 PM
lsturbo*'s Avatar
Default Re: Attaching a K&N to stock intake pipe(pict request)? (gsilnc)
Thats exactly what I want to do, but where did you get that adapter piece?
Old Apr 6, 2008 | 04:48 PM
gsilnc's Avatar
no adapter... it was sawed off at the point of placement xD
Old Apr 6, 2008 | 06:58 PM
I AM WEASEL's Avatar
why not just get the knn "drop in" oem replacement filter?
Old Apr 6, 2008 | 07:10 PM
DAtegLs's Avatar
better yet...why not just do it right and get a real intake?
Old Apr 6, 2008 | 08:41 PM
DiMpL3s.'s Avatar
Default Re: Attaching a K&N to stock intake pipe(pict request)? (DAtegLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAtegLs &raquo;</TD></TR><TR><TD CLASS="quote">better yet...why not just do it right and get a real intake?</TD></TR></TABLE>
Old Apr 6, 2008 | 09:00 PM
Avenged7x's Avatar
Meh, i use an aftermarket filter on my stock pipe since a rock destroyed my air intake box, but really it doesnt matter IMO, i would just do what your doing rather then buy a "real" intake unless u want to go CAI. I just used a filter that was the same diameter as the hole and wedged it in there.
Old Apr 6, 2008 | 09:04 PM
angel_i's Avatar
At the end of the intake tube was a section of 3" Exhaust adapter pipe and attached to a stock integra air filter, but any filter would work.
Old Apr 7, 2008 | 07:56 AM
jomama's Avatar
because the bpi velocity stack with the K&N RF-1048 filter just kicks *** as a budget intake?
not saying it's the best, but it is a hands-down great alternative to others out there!!! besides, dynos don't lie:
https://honda-tech.com/zerothread?id=2231492
check out my thread:
https://honda-tech.com/zerothread?id=2221274 ... i'm also going to have this on my gsr (same intake arm as the OP's... i just took off that resonator piece and sort of plugged up the hole...
http://www.bpinitiatives.com/ =
Old Apr 7, 2008 | 11:45 AM
lsturbo*'s Avatar
Well, I am going turbo sooner than later, so I just wanted a quick fix because I couldn't stand to put the stock "box" back on. I think I'm gonna go with the $15 Autozone K&N mock off, and find an efficient method of attaching it. I might even need a small piece of aluminum coulping to tighten the clamp down to. Thanks for the picts, they give me something to work off of....
Old Apr 7, 2008 | 12:02 PM
xlilninjax's Avatar
Default Re: (lsturbo*)
you can always go on ebay and buy the intake but THROW AWAY THE FILTER. just use the pipe and go out and buy like a k&n filter and there you have it.
Old Apr 7, 2008 | 12:05 PM
DAtegLs's Avatar
Default Re: (xlilninjax)
AHAH! problem solved!
Old Apr 7, 2008 | 01:51 PM
lsturbo*'s Avatar
Default Re: (DAtegLs)
I actually just got back from Autozone...This filter was $16 and fit perfectly. It was actually a slight interference fit so it's a good seal. Remember, I am just looking for a temp air intake, by no means am I pushing a short ram intake ( or warm air intake as I prefer to call it..ha ha) because eventually I will be going turbo. Thanks again for the picts...
Old Apr 7, 2008 | 01:54 PM
gsilnc's Avatar
looks good
imma look into a velocity stack now :D
thx jomama
mjsotelo91
27
Nov 18, 2007 11:03 AM
MDM
19
Jul 6, 2007 05:47 PM
loner714
Apr 20, 2007 01:47 PM
SuperTomcat
Jan 8, 2007 07:34 PM
Nuke209
Dec 14, 2005 03:19 PM
