engine pics
h23 with brc pistons,nascar sleves,custom rods,full rebulid
head:stage 2 p&p,5 angle valve job with all new honda valves and O-ringed head with copper head gasket
runing 9.8:1 comp
15psi every day and 20psi when i go to the track
runing 9.8:1 comp
runing 9.8:1 comp
runing 9.8:1 comp
runing 9.8:1 comp
how much do you put to the wheels and the flywheel? is this track curvy or straight and what times? how bad is your lag?
runing 9.8:1 comp
Am just getting it going a few weeks ago with the new bulit motor so ill hit the drag in a few more weeks i still got to go to the dyno and tune it
i get full boost by 4200rpms the turbo it a t3/t04e 60 trim
keeping it rich
"keeping it real" huff
for real: i guess its a bit safer to run rich then to take a chance at running lean
Depends on your compression ratio, boost, head gasket thickness, amout of fuel, and I think your stroke.
because its a pic of the engine in my accord
