temps and starting problem
Old Apr 6, 2008 | 02:37 PM
3rdgenintegra48's Avatar
Default temps and starting problem
car turns but doesnt start..so i hold the gas peddle down then it starts up..release gas peddle..but idles low for a couple of seconds on start up..
Another problem is my temps mostly stays normal but occasionaly it will go 1/4 of the way to the H...then back to normal temp as i drive
Old Apr 7, 2008 | 09:54 PM
h-t_ruinedmylife's Avatar
Default Re: temps and starting problem (3rdgenintegra48)
The temp gauge may just be ground wire messing with you. idling, dont know, sorry
Old Apr 8, 2008 | 08:32 AM
JDM-Riders's Avatar
Default Re: temps and starting problem (h-t_ruinedmylife)
Temp thing may be your thermostat going out or acting out... I had the same problem and fixed it with a new thermostat.
The starting problem may be your main relay or fuel pump (probably not getting enough fuel to initially start)...
Old Apr 8, 2008 | 10:32 AM
Default Re: temps and starting problem (JDM-Riders)
thanks for the replies..also my fans were not working also..but i took the car in to find out the head gasket was blown so now i got to raise up the cash to fix
Asmooh
18
Apr 15, 2014 07:05 AM
hydroflip
Jul 7, 2007 03:45 PM
kitkatR
Oct 31, 2004 07:15 PM
garrybloom
Oct 7, 2004 04:17 PM
