Suspension & Brakes Theory, alignment, spring rates....
Stuck Coilover Sleeve...
Old Apr 6, 2008 | 11:57 AM
B18C_EJ8's Avatar
Default Stuck Coilover Sleeve...
So in the process of pulling my engine, I discovered that I had a blown shock up front.
I figured it would be a good idea to change out both front shocks since they were installed at the same time, so I ordered a new pair. Today, I went out to transfer the coilover setup from the old shocks to the new ones, but the sleeve (threaded adjustment portion) is stuck ever so tightly to the shock.
Tried soaking it in PB blaster around the shock, and beating on it with a flathead/hammer, but it just won't budge...
I searched the archives, and found a similar issue, but there were no responses on how to get them apart....
I can't imagine no one else has had this issue...
Old Apr 7, 2008 | 04:49 AM
B18C_EJ8's Avatar
Any advice from the Monday crew?
Old Apr 7, 2008 | 05:04 PM
nub's Avatar
nub
Default Re: Stuck Coilover Sleeve... (B18C_EJ8)
you could try heating the sleeve with a torch.since its aluminum it will expand much quicker than the steel of the strut body. i would thread the lower perch on and carefully heat it. once hot turn the stut upside down and hold it by the perch (gloves of course) and slam the shaft staight down onto your workbench or the ground. since youre replacing them you dont have to worry about damaging the strut. gl
Old Apr 10, 2008 | 03:53 PM
B18C_EJ8's Avatar
^^^ Worked like a friggin charm!!
Thanks for the suggestion! Didn't work by slamming it down; had to beat on the perch with a rubber mallet after heating for a minute, but they're both off...
$24 torch was better than paying $30something dollars each for two sleeves.
Old Apr 10, 2008 | 04:28 PM
got_boost99's Avatar
Default Re: (B18C_EJ8)
I have the same problem, I'm going to try doing this... Glad it worked for you...
Old Apr 11, 2008 | 12:30 PM
Targa250R's Avatar
be professional
Default Re: (got_boost99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by got_boost99 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem, I'm going to try doing this... Glad it worked for you...</TD></TR></TABLE>
Do not use this method if you plan on re-using the dampers. The amount of heat created by a torch will damage them.
Old Apr 11, 2008 | 12:37 PM
B18C_EJ8's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Do not use this method if you plan on re-using the dampers. The amount of heat created by a torch will damage them.</TD></TR></TABLE>
Not to mention that the oil from inside the shock & rust & road grime STANK when they're on fire.
agustintorre
Suspension & Brakes
19
Aug 31, 2012 01:54 PM
neozero999
Suspension & Brakes
11
Dec 20, 2008 03:02 AM
phatsindabuildin
Sep 12, 2006 04:32 PM
Civic321
Suspension & Brakes
Jan 17, 2006 07:17 PM
gsr_to_the_MAX
Aug 7, 2004 11:21 PM
