timing marks wont line up.
i went to adjust the timing on my car its a d15b7 but its dpfi. i cant get the marks on the pulley to line up with the pointer on the cover. the timing belt gears are lined up perfectly with the marks. am i doing something wrong?
ya thats the only thing i could think of too. but i dont know cause you can put a si dizzy on a d15b2 for mpfi and it works. its a dpfi obd0 dizzy on there. i guess i should just stop being lazy and convert it to mpfi i allready got all the stuff just gota convert my harness and get a gasket. thanks.
its an ef though you check the codes by the little blinking led on the ecu. or is there a service contector there too like on the eg's?? honestly i probably wont even mess with it till i do mpfi. thanks though.
you still have a SCS in the same spot as all other civics. the ecu will change the timing to compensate for all kinds of things, so you have to jump the connector to keep base timing. if you have been setting timing without doing this you have been very lucky.
NatedoggAZ
14
Apr 13, 2005 09:51 AM
