Wire tuck O2 Sensor code
I just finished my passenger side wire tuck and had to extend all 6 wires in the harness clip. Now I am throwing an Autozone code P0131, which says it is a Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage code.
yeah i used the same size wire, i relocated the engine compartment fuse box to the trunk and i do think that that is what has caused my problem. im trying to find a new harness to try to eliminate possibilitys.
