fender
Old Apr 6, 2008 | 07:36 AM
3lo's Avatar
3lo
Default fender
how hard is to change the fender, any tips and advice on installing and aligning?
Old Apr 6, 2008 | 07:45 AM
jax97hx's Avatar
Default Re: fender (3lo)
ill let you know soon enough i got some carbon fiber ones on the way.
Old Apr 6, 2008 | 07:46 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: fender (jax97hx)
Its not that hard. at all. if i remember correctly, you will have to remove the side-skirt to get to a bolt.
Old Apr 6, 2008 | 07:52 AM
3lo's Avatar
3lo
what about headlight and bumper, are they staying ?
Old Apr 6, 2008 | 09:51 AM
EcivicG's Avatar
Default Re: (3lo)
youll need to remove the inner liner, i don't have any so i can't tell you how, but i hear its really easy.
next you have the 3 or 4 10mm bolts on the topside in the bay, then open your door and hammer out the pin that holds your door from hyper extending. go outside and then remove the 10mm bolt up top on the side, then torwards the bottom. after all that one more bolt is hiding and you need to take the side skirt off.
the headlight can stay on but the corner needs to come off.
and you'll need to remove the bolt that attatches the bumper to the fender
edit--**** i just saw you didn't specify what car you even have....
this is what i had to do to remove the fenders on my eg coupe
Modified by EcivicG at 10:59 AM 4/6/2008
Old Apr 6, 2008 | 09:57 AM
silverekcoupe's Avatar
Default Help
sorry man this has nothing to do with your post i just need to know how to get past being a trial user, i cant send pm's or even post in most threads, someone please help me out!!!
chiggin
Honda Civic (2006 - 2015)
Feb 22, 2009 03:45 PM
R1C3Rxs
Apr 22, 2008 02:36 PM
j_man104
Jan 11, 2006 08:31 PM
PY2KITR1060
May 19, 2002 07:25 PM
Calavera
May 3, 2002 05:33 AM
