NEED HELP!!!!!!!!!!!!!!!!!
Old Apr 6, 2008 | 02:15 AM
soysauce90CRXsi's Avatar
Default Need help choosing a motor!
I have a 90 CRX Si. I was wondering if i should keep my motor thats in my car and rebuild it then boost it, or do a motor swap and go that route. I haver 2000 dollars to play with so idk. So any comments would help>
Modified by soysauce90CRXsi at 7:47 PM 4/9/2008
Old Apr 6, 2008 | 02:23 AM
EFRue57's Avatar
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (soysauce90CRXsi)
you're not going to be able to rebuild and boost your motor for $2000. you can try but you're gonna end up blowing your motor. do a b series swap. you can get everything for under $2000 and it will give you a good hp gain and it will be reliable.
Old Apr 7, 2008 | 01:18 PM
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (EFRue57)
wut do u think if money isn't an issue. Do u think i should keep my motor cause its there, or should i do a crazy swap. I'd kinda want to pull up to the strip and smoke some one with my little D16A6!!!!! And then they would ask me wut I have and i'd say a little 1.6 SOHC. I don't know it kinda sound weird but I dont want to do V-TEC because my buddy did a swap in to his CRX and he said its A pain wiring vtec to his car but I don't know.I would really appreciate some ones advice.
Old Apr 7, 2008 | 01:24 PM
escourt23's Avatar
I would have to agree with EFRue. As much fun as it would be to beat someone with the mighty D, its not getting the most for your dollars! Do the B swap. The wiring is a breeze. Just get a jumper harness from Rywire if you are not that comfortable with wiring diagrams.
Old Apr 7, 2008 | 02:01 PM
draperj09's Avatar
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (escourt23)
i am leaning towards b-series with lsd myself. just search around.
Old Apr 7, 2008 | 02:03 PM
draperj09's Avatar
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (draperj09)
by the way for future posts, pick a better title, like "which setup should I run in my ___?" you'll get more replies, and after all it is honda-tech help is why we are here
Old Apr 7, 2008 | 02:23 PM
pandarex's Avatar
jackson racing supercharger is some of the best bang for buck imo. but i would make sure your a6 is strong if your thinking of doing it.
Old Apr 7, 2008 | 02:45 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">The best engine for your honda is WHATEVER YOU CAN AFFORD TO BUY!
If you have $1000, DOHC ZC.
If you have $2000, get a 1st gen b16a. It'll cost that much to get it in.
If you have $4000, get a GSR/B18C1.
If you have $5500, get a ITR/B18C5.
If you have $10K, and no use for your car for a month or two... get a K20.
Edited for the Whiners:
This is NOT a complete list, as there are mini-mes, LS-VTEC swaps, budget/poor man's ITRs, etc. Use the damn search button a bit more religiously.
What's the best engine for boost... the one that gets TUNED properly.
What's the best engine for drag racing... the one you spend the most money on making FAST.
What's the best engine for road racing... same thing.
What's the most reliable engine... the one you MAINTAIN religiously.
What's the cheapest engine... the one that's in your car.</TD></TR></TABLE>
Old Apr 7, 2008 | 02:50 PM
tree fingers's Avatar
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">
own
&lt;/thread&gt;
Old Apr 7, 2008 | 02:54 PM
EFRue57's Avatar
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (pandarex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pandarex &raquo;</TD></TR><TR><TD CLASS="quote">jackson racing supercharger is some of the best bang for buck imo. but i would make sure your a6 is strong if your thinking of doing it.</TD></TR></TABLE>
i'd have to disagree. you spend $2000 on a supercharger and gain 50-60 hp. and then you have to factor in that the motor probably has some miles on it being an 18 year old car, which means reliability is an issue, you have to factor in tuning, which on an obd0 car is not a very easy thing to do well, so then you might have to factor in converting to obd1, then also any extras you might run in to.
Old Apr 7, 2008 | 03:37 PM
Cuban Racer's Avatar
I have a d15b7 block with a d16y8 head. I had the crank Edged, balanced and blueprinted. Crower rods and stock pistons. New main bearings and rod bearings complete bottom end gasket get. The head was milled and I got a complete Gude Performance Head Package which includes.
Ported and Polished Cylinder Head
High Compression Radius Cylinder
Racing Valve Grind
Ported Intake Manifold
Ported Throttle Body
Camshaft(s)
ECU
I also use a Skunk 2 intake manifold that was matched ported to the head. I'm getting 165 to the wheels and this set up cost me about $2000.00. I Know all the Bseries guys are going to talk down to me but I went with this set up because its super reliable and I drive my car everyday, and this set up with an SI tranny revs rpms quick and its pretty fast this same set up on a dohc would cost you double and I have no trouble at all killing 1.8 vtec's with bolt ons.
Old Apr 7, 2008 | 07:06 PM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soysauce90CRXsi &raquo;</TD></TR><TR><TD CLASS="quote">wut do u think if money isn't an issue. Do u think i should keep my motor cause its there, or should i do a crazy swap. I'd kinda want to pull up to the strip and smoke some one with my little D16A6!!!!! And then they would ask me wut I have and i'd say a little 1.6 SOHC. I don't know it kinda sound weird but I dont want to do V-TEC because my buddy did a swap in to his CRX and he said its A pain wiring vtec to his car but I don't know.I would really appreciate some ones advice. </TD></TR></TABLE>
Its not like your going to be able to afford a crazy swap with 2k.
Old Apr 7, 2008 | 10:38 PM
My_EFsedan's Avatar
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (~sp33~)
my brother and I built a b20vtec for 1100 that ran 12's in a crx, thats stock internals too. tuned by Advance made 191hp/157 trq GL with 2g's
Old Apr 8, 2008 | 12:23 AM
Default Re: NEED HELP!!!!!!!!!!!!!!!!! (My_EFsedan)
Thanks guys this is really helpful. I have to think about it alot. I really appreciate it alot. Thats a really good idea(my_EFsedan). Well im kindda new to honda tech thing there dr_latino so i really appreciate the time and effort you took to print screen, to copy and paste onto a new image and save to the internet to show that i was wrong. I'm flattered!!!!!!!!!!!!!!
Modified by soysauce90CRXsi at 1:34 AM 4/8/2008
ftanka0
Honda CR-V & Element
Apr 22, 2013 12:03 PM
roks94'HATCH
Jan 31, 2011 11:38 AM
slumpinhonda
Aug 10, 2007 04:21 AM
layinlowon14s
58
Mar 12, 2007 12:53 AM
Darkhare
18
Sep 15, 2004 07:54 AM
