WTH....My car wont even Crank
Im stumped....I drove my car fine the other day...and now when I try to start my car, it doesent even crank.......the weird thing is that all my lights work/ radio with my system works fine... the only thing that doesent turn on is my HIDz
I even tried to jump it, but it still doesent crank at all....also when i turn my key i dont hear my fuel pump turning on .....
Any of you guys had this same or similar problem before? any suggestions???
Check the starter... If a car suddenly dont want to crank then it either the starter or the relay, could be the wiring but doubt it.
Even if the starter is bad, when you try to crank. you should hear the relay click, if it doesnt click and relay is bad.
Tad
Jan 3, 2006 06:37 PM
