adequate floor jack point image
i'm wondering where the floor jack point under the front of my 94 teg is.. i don't mean the side points.. i need to get the front up even at the same time and jack it up on stands i've seen this image http://www.team-integra.net/se...D=581 so pls don't refer me to it... it really doesn't illustrate where to put it...
Lift with the floor jack at the front cross member. Deep enough so it doesn't slip out. Right behind where it makes the T <--
Jack stands on the sides of the car at the proper points behind the wheels. NOT like that guy has it on his sway-bar!
thanks... i understand that i can use that typically... but i just spoke with the acura dealer, they said there isnt a cross member... i've done this before on lots of cars... this one has so many plastic and gel coated pieces that it's hard to find something solid... i'm relly confused and aggravated because such a simple issue makes me feel quite stupid... i am still looking for an image of the contact point to actually use...
thanks very much for the help with my pathetic struggles.
