main relay on DA
just swapped an engine into my da and it woont turn over.
i have fuel pump lights but no starter. i dont know were the starter relay is or what it looks like. i removed all the heater stuff is that why?
im runny power straight to the starter from the battery
On a DA the main relay is either a brown or black box that has one plug-in into it. It is held in place by one screw on a bracket. The location is to the left of the steering wheel, under the dash.
Good luck.
-Rik
Good luck.
-Rik
have u tryed to all ur grounds like the engine to chasis ground and if all the grounds are good then u need a new starter..also check ur fuse box by hood release for starter signal and if u need replace tht fuse it should be ,,,,from top second row third to last check tht one
yea thts true the main relay is brown and should say mitsuba or something and should say 12v on it tht little thing when going bad ur car will start sumtimes like a bad fuel pump lol change it
i really don't know about that main rely but most of the time you can check and see if the rely is bad by looking at the board of the rely, if the solders are broken or wore down, you'll have to replace it. or you can fix it if your a good solderer
EK B18c
22
Apr 21, 2012 03:08 PM
