distributor or coil or what please help ?
Old Apr 5, 2008 | 06:06 PM
homer_eps's Avatar
Default distributor or coil or what please help ?
i have no idea what is wrong with my car all sensors are working , just bought new spark plugs , and put them on , car would just bog out itsounds like it had to much gas
so i took off spark plugs and were filled with gas like soaked , you think it might be my coil , not enough spark please help need to get my carrunning before monday
Old Apr 5, 2008 | 06:17 PM
homer_eps's Avatar
Default Re: distributor or coil or what please help ? (homer_eps)
please
Old Apr 5, 2008 | 06:22 PM
slowcivic2k's Avatar
umm, check your firing order before replacing parts......
Old Apr 5, 2008 | 06:23 PM
homer_eps's Avatar
Default Re: distributor or coil or what please help ? (slowcivic2k)
i did there correct ...any other suggestion
Old Apr 5, 2008 | 06:42 PM
hondabadtoy's Avatar
1. check dizzy cap. see if its loose, missing the coil spring, rotor is on right, and wires.
2. check the compression in the cylinders. a compression tester is $15 at autozone and a very usefull tool (even if its unnessicary this time)
3. did u put Dilect-grease on the connection points of ur wires? If not try that next, one or all of ur spark plugs could be disconnecting themselves (so to speak) s u drive.
Old Apr 5, 2008 | 08:12 PM
homer_eps's Avatar
Default Re: distributor or coil or what please help ? (hondabadtoy)
ok thnks
Old Apr 5, 2008 | 08:17 PM
suspendedHatch's Avatar
Is your car stock? Did you put some big injectors on there? All FOUR spark plugs are doused with gas? Was it running fire before?
Sounds like a fuel problem.
Old Apr 5, 2008 | 08:21 PM
homer_eps's Avatar
Default Re: distributor or coil or what please help ? (suspendedHatch)
i dont know any history of that motor its single cam vtec , stock injectors i believe
but im thinking the coil is bad thats why thre is not enough spark when i changed the dist. cap the older cap look ed really bad , so tomorrow i am going to change the rotor and the coil ill see what happens
Old Apr 7, 2008 | 04:07 PM
homer_eps's Avatar
i think i know why now the dumb *** who put the motor on the car ran the injector pulse line to a ground
Old Apr 7, 2008 | 05:44 PM
DCSportEJ1Civic's Avatar
the injector pulse is a ground.
Old Apr 8, 2008 | 05:27 AM
homer_eps's Avatar
Default Re: distributor or coil or what please help ? (DCSportEJ1Civic)
but i dont think you can actually grounded , then it would mess up the actuall pulse of the injector right
Old Apr 8, 2008 | 07:19 PM
well yea. it should always have power but the ground should be a pulse. so what prompted this problem? all you did was change the spark plugs? you didnt unhook anything else. im kinda confused on what happened.
Old Apr 9, 2008 | 08:09 PM
homer_eps's Avatar
sorry for not putting the info but i bought this car , and it was bogging out since i got it the reason why i bought it is becouse of the shell not the motor since im swaping it with a ls vtec but anyway i still need the single cam to go to work , so thats why si i started eliminating problems that i thought it had like coil sparkplugs map sensor tps , and the iavc and found out there was no knock sensor and the injectors were conected to a ground well anyway lets just forgwet about it i made the guy who sold it for me to pay for the mechanic but i will ask the mechanic what was wrong with its o we can all be aware of this mistakes that other people do
Noo_Ish_mee
Jun 27, 2016 02:44 PM
ls19integra95
Apr 15, 2007 11:40 AM
ef2 from hell
Nov 25, 2006 03:07 PM
EblazeK
Aug 4, 2006 01:02 PM
gottagofaster
Oct 22, 2005 04:50 PM
