b series prob....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 »</TD></TR><TR><TD CLASS="quote">car won't start</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDERHOOD-TOOLBOX »</TD></TR><TR><TD CLASS="quote">CRANK THE CAR AND DRIVE IT, LEAVE IT RUNNING AND UNPLUG THE TPS TO SEE IF IT MAKES A DIF.. IF NO DIF, ITS BAD OR HAS A BAD CONNECTION.</TD></TR></TABLE>
Reading comprehension anyone
and please stop with the caps already.
I dont think the TPS is your problem.
Are you getting fuel and spark, are the main relay and fuel pump turning on (you should hear a click and a "humm")? check your fuses, grounds and battery connections. is there gas is the tank? Sorry I have to ask.
can you describe your problem a bit more? is it turning over or not, or making weird noises?
and please stop with the caps already.I dont think the TPS is your problem.
4gencivicef9
May 22, 2007 06:28 PM
love_5gen
11
Feb 25, 2007 11:22 PM
