Can I put AC in my civic hx (has continuous variable trans)
I have a 1998 Honda Civic HX and it has a continuous variable transmission. Can I put an air conditioner in it? I am having a baby next month and I'll be pretty screwed it I can't. It doesn't have an AC button in the car and I keep on getting different answers... PLEASE HELP!!
ok i have a 1998 civic hx with a manual tranny. to my knowledge the tranny you have doesnt matter as to weather or not you can install the a/c, and the part number is not different for auto or manual as quoted from my installtion manual. i couldnt find a good factory kit anywhere, and i was considering the aftermarket kit, but my research proved, that if i had problems, only their pieces would fit, as their kit is not a copy of the factory by any means, what i did do was a LOT of various searching, and also searching again on ebay. on ebay i found a dealer whose parts is availiable online. i went through their site, which has two sites,
DCHAutomotiveparts.com and http://www.normreevestemecula.com both are basically the same.
anyhoo, i talked to the dealer, and the kit gives you EVERYTHING for a factory install except for the refridgerant itself. they give you all compnents, even the stickers that go under the hood. i got the whole box ground shipped to my apartment for $750 it works great. as for the a/c button here is the fun. these kits are very hard to get ahold of. this dealer parts people figured out that the 99-00 kit is the same except for the little black a/c pushbutton that your finger pushes. [when you say you dont have one, you do its just covered by a delete cover] so they order a 99-00 ac kit, and they order a pushbutton for a 96-98, and push the button through the handle holes in the side of the box, and send it out to you. it is genious. it works great. and the only problem i had, was the high side service port kept seeping out slowly, and i couldnt warrenty the hose, [yes its even waranteed!] because i lost the reciept, so i replaced the care of the valve, ti still seeped out, and well, i work on mercedes for a living, and so i had a spare cap for the 134a high side port, put it on, and bam! its sealed perfectly! so let me know if you have any questions.
chrysler kid
49
Aug 17, 2016 03:31 PM
ClubRX
Feb 19, 2008 01:14 PM
