vtec question
Old Apr 5, 2008 | 03:09 PM
moores55's Avatar
Default vtec question
Ok long story but need a short answer. I was tuned a few weeks ago and the tuner just send me my kal. I am running a k24a1 with a greddy kit. I started looking at it and i saw that the tuner did not use the a3 greddy base map to tune off of, instead he used the tsx base map. The problem that i am having is that the tsx uses "true" vtec with 3 lobes and dose not kick in till 4600rpm's unlike the a3/a1 motors that kick in at 2200rpm's. because of this My car has a big dip in power at crossover and leans out. The tuner tuned the car with the vtec point at 4500 and I don't think thats right. I did not make the power i should have and i think this could be one of the reasons. Am i right?
Old Apr 5, 2008 | 05:04 PM
moores55's Avatar
Default Re: vtec question (moores55)
anyone?
Old Apr 5, 2008 | 07:53 PM
Tyte-S's Avatar
I'm not claiming to be an expert on tuning,because I'm not. But it makes sense to me that if Vtec is engaging at the wrong point that it may cause your car to lean out. More air in = need for more fuel. If it's engaging at the wrong point I suppose that the car may not get the correct amount of fuel and cause you to lean out. I think that's what your saying... Bring it to his attention, make sure everything's good, and have him retune it of need be. I'm not sure if that helps you any. Sorry if it doesn't.
Old Apr 6, 2008 | 09:39 AM
Master23's Avatar
Why would he use the TSX base map to turn the K24a1? Doesn't make any sense. Talk to your tuner ask him why he used the TSX base map instead of the a3 base map. There must be a reason why he used the TSX base map to tune off on unless he was confused what motor you had.
Old Apr 7, 2008 | 08:48 AM
myhondasfaster's Avatar
Default Re: vtec question (Master23)
wasnt vtec invented to save gas??
Old Apr 7, 2008 | 10:02 AM
Master23's Avatar
Default Re: vtec question (myhondasfaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhondasfaster &raquo;</TD></TR><TR><TD CLASS="quote">wasnt vtec invented to save gas??</TD></TR></TABLE>
Old Apr 7, 2008 | 10:41 AM
moores55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhondasfaster &raquo;</TD></TR><TR><TD CLASS="quote">wasnt vtec invented to save gas??</TD></TR></TABLE> You fail.
Old Apr 7, 2008 | 11:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 &raquo;</TD></TR><TR><TD CLASS="quote"> You fail. </TD></TR></TABLE>
not so sure about that,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wikipedia &raquo;</TD></TR><TR><TD CLASS="quote">VTEC (Variable Valve Timing and Lift Electronic Control) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine. This system uses two camshaft profiles and electronically selects between the profiles.</TD></TR></TABLE>
you fail
Old Apr 7, 2008 | 11:43 AM
scmil95eg's Avatar
When I first put in the EMS, VTEC was set way too high as well. Started driving it around and it felt & sounded really different/bad. Changed it so the psuedo-VTEC is set to engage at @ 20% TPS and 1700 RPM. Sounds normal, feels great, no dip in torque till after 6000 rpm.
Remember, A3 VTEC just gives you both intake valves, not a 3rd lobe.
Old Apr 7, 2008 | 01:00 PM
Danny BAGDAD's Avatar
you fail</TD></TR></TABLE>
http://en.wikipedia.org/wiki/Volumetric_efficiency
educate yourself man...volumetric efficiency doesn't mean more effecient on gas
Old Apr 7, 2008 | 01:06 PM
Default Re: vtec question (Danny BAGDAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danny BAGDAD &raquo;</TD></TR><TR><TD CLASS="quote">
educate yourself man...volumetric efficiency doesn't mean more effecient on gas</TD></TR></TABLE>
we're both right in a way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wikipedia &raquo;</TD></TR><TR><TD CLASS="quote">Some later variations of the system were designed solely to provide improvements in fuel efficiency, or increased power output as well as improved fuel efficiency.</TD></TR></TABLE>
Old Apr 7, 2008 | 01:11 PM
Tyte-S's Avatar
You fail for using Wikipedia as a source. Anyone can go on there and edit anything. Read the bottom of the first paragraph on the link that he provided.
Modified by Tyte-S at 2:49 PM 4/7/2008
Old Apr 7, 2008 | 01:47 PM
Master23's Avatar
Default Re: vtec question (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">You fail for using Wikipedia as a source. Anyone can go on there and edit anything. Read the bottom of the first paragraph. </TD></TR></TABLE>
Old Apr 7, 2008 | 02:24 PM
you all fail for drivin hondas
Old Apr 7, 2008 | 05:17 PM
Tyte-S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhondasfaster &raquo;</TD></TR><TR><TD CLASS="quote">you all fail for drivin hondas </TD></TR></TABLE>
Old Apr 7, 2008 | 06:04 PM
not being a jerk, just jokin around, hence the wave
Old Apr 7, 2008 | 06:24 PM
Tyte-S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhondasfaster &raquo;</TD></TR><TR><TD CLASS="quote">not being a jerk, just jokin around, hence the wave
Old Apr 7, 2008 | 06:34 PM
SkankyEJ7's Avatar
Old Apr 7, 2008 | 07:48 PM
moores55's Avatar
Default Re: vtec question (SkankyEJ7)
Omg, that's the best thing i have seen all week.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 9, 2008 | 03:16 PM
Tyte-S's Avatar
Bump for a follow up?
Old Apr 9, 2008 | 03:26 PM
Pat_S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">You fail for using Wikipedia as a source. Anyone can go on there and edit anything. Read the bottom of the first paragraph on the link that he provided.
Modified by Tyte-S at 2:49 PM 4/7/2008</TD></TR></TABLE>
If anyone wants a more detailed and accurate source to explore, Amazon.com is the way to go.
unusual71
Engine Management and Tuning
10
Sep 10, 2012 08:01 PM
cpgottabuh
Jul 23, 2008 12:11 PM
ken2830
Dec 25, 2006 11:08 AM
turboH22Aakkord
Oct 8, 2005 05:15 AM
Outsane
Mar 11, 2005 11:22 PM
