tranny swap for D15
Old Jul 10, 2002 | 01:51 PM
Mike D's Avatar
Default tranny swap for D15
ok i remember reading that the ex trans can be swapped onto a D15 with no work correct??
If this is true what are the benefits? is it worth it? Im going to need to change my clutch soon so i figured while i have it out, why not replace it.
Also, where would be a good place to find one of these?
TIA
Mike D
Old Jul 10, 2002 | 02:00 PM
Spade's Avatar
Default Re: tranny swap for D15 (Mike D)
As long as you are swapping a Hydro tranny for a Hydro tranny or a Cable for a Cable the D's will bolt right on.
I would suggest the tranny it's shorter gears are very nice. But, if you are going to do this, an LSD is that much better.
Old Jul 10, 2002 | 02:06 PM
Mike D's Avatar
Default Re: tranny swap for D15 (Spade)
are you suggesting i put an lsd with the ex trans? yeah that would be ideal but cash doesnt permit at the moment.
Can you tell me if i have a hydro or cable tranny?.....its a 92 dx hatch with the mentioned D15B
And where is the best place to get one and for how much?
Mike D
Old Jul 10, 2002 | 02:20 PM
whobeedoobee's Avatar
92+ s/b a hydro
Old Jul 11, 2002 | 03:16 AM
Mista Bone's Avatar
D Tranny Guru
swapping in a EX/Si tranny onto the D15B7 is the BEST mod for the money you can do.
Trust me.
http://home.cinci.rr.com/mistab0ne/tranny.html
Old Jul 11, 2002 | 07:23 AM
Mike D's Avatar
Default Re: tranny swap for D15 (Mista Bone)
Trust me.
Excellent write up Mista Bone. So the ex/si tranny will bolt straight up to my 92 d15b? Also, where do you recommend getting one of the trannys for a good price?
Thanks for the great info.
Mike D
Old Jul 12, 2002 | 03:05 AM
Mista Bone's Avatar
D Tranny Guru
2.4 hours to swap the trannys is my best time so far.
AND this was at Mid Ohio in the paddock, not in a heated garage!
Old Jul 12, 2002 | 04:12 AM
TurBoXBirD16's Avatar
a NEWBIE question here
what's LSD??
is it another kind of tranny??
where i can find them?
Old Jul 12, 2002 | 08:27 AM
RSZero1's Avatar
Default Re: tranny swap for D15 (xbird)
LSD - a mind altering chemical substance known to produce halucenogenic and vibrant visions highly abused during the seventies.
Limited Slip Differential which evenly distributes power to the drive wheels, eliminates torque-steer, enhances take off under hard acceleration.
= Same results, enjoy your drive
[Modified by RSZero1, 9:28 AM 7/12/2002]
Old Jul 12, 2002 | 09:11 AM
Default Re: tranny swap for D15 (RSZero1)
ok...
then is LSD an tranny?? or is it something that i can ADD to my car??
thanks
Old Jul 12, 2002 | 09:17 AM
RSZero1's Avatar
You would be adding this to your car. in place of your stock differential (between your axles)
Old Jul 12, 2002 | 09:20 AM
that's INSIDE the tranny, right??
Old Jul 12, 2002 | 09:27 AM
Mike D's Avatar
yes, teh differential is within the tranny.
Old Jul 12, 2002 | 09:28 AM
thanks!!!!!!!!!!!!!!!!!!!
92 teggy
Feb 12, 2010 05:45 PM
lakai_19
Oct 3, 2007 05:28 PM
SmogKing
Sep 7, 2006 04:53 PM
