tranny swap for D15
tranny swap for D15
ok i remember reading that the ex trans can be swapped onto a D15 with no work correct??
If this is true what are the benefits? is it worth it? Im going to need to change my clutch soon so i figured while i have it out, why not replace it.
Also, where would be a good place to find one of these?
TIA
Mike D
TIA
Mike D
Re: tranny swap for D15 (Mike D)
As long as you are swapping a Hydro tranny for a Hydro tranny or a Cable for a Cable the D's will bolt right on.
I would suggest the tranny it's shorter gears are very nice. But, if you are going to do this, an LSD is that much better.
Re: tranny swap for D15 (Spade)
are you suggesting i put an lsd with the ex trans? yeah that would be ideal but cash doesnt permit at the moment.
Can you tell me if i have a hydro or cable tranny?.....its a 92 dx hatch with the mentioned D15B
And where is the best place to get one and for how much?
Mike D
Mike D
D Tranny Guru
swapping in a EX/Si tranny onto the D15B7 is the BEST mod for the money you can do.
Trust me.
http://home.cinci.rr.com/mistab0ne/tranny.html
Trust me.
Re: tranny swap for D15 (Mista Bone)
Trust me.
Trust me.
Excellent write up Mista Bone. So the ex/si tranny will bolt straight up to my 92 d15b? Also, where do you recommend getting one of the trannys for a good price?
Thanks for the great info.
Mike D
Re: tranny swap for D15 (xbird)
LSD - a mind altering chemical substance known to produce halucenogenic and vibrant visions highly abused during the seventies.
Limited Slip Differential which evenly distributes power to the drive wheels, eliminates torque-steer, enhances take off under hard acceleration.
= Same results, enjoy your drive
[Modified by RSZero1, 9:28 AM 7/12/2002]
