Will -30% work with DSM's ?
Old Jul 10, 2002 | 01:28 PM
legendboy's Avatar
Default Will -30% work with DSM's ?
I am going boost. I know the Safc setup should have around -40% to run DSM's and boost but I have an oldschool safc already, + - 30% max. Can this still work using DSM's and Boost without fpr and fmu? I want to buy a new Safc but $ a little tight now. There are now archived posts on oldschool safc's at all. Thanks guys
Old Jul 10, 2002 | 02:03 PM
ArizonaTurbo's Avatar
Default Re: Will -30% work with DSM's ? (legendboy)
440cc injector @ 70% = 308cc
So it is almost equivelent to a 310cc injector which should idle.
Old Jul 10, 2002 | 04:54 PM
TaylorSPL's Avatar
Default Re: Will -30% work with DSM's ? (TurbochargedSER)
Just to be a nit picky little ******* the turbo DSM injectors are 450cc and the 1g turbo automatic DSM's are 390cc so you might want to look into those.
Old Jul 10, 2002 | 05:07 PM
DLB1994's Avatar
u plan on doing the afc hack or u going to still need a fmu
Old Jul 10, 2002 | 05:15 PM
rioninja's Avatar
It will idle fine. However, will definatly run rich throughout the rpm range. You should be able to run it temporarily, but it wont run great. Also, keep in mind that at only -30% lean, you will only have enough room to boost about 7psi on the vafc mod.
Old Jul 10, 2002 | 07:27 PM
legendboy's Avatar
Default Re: Will -30% work with DSM's ? (RioNinja)
Nice, so simple So I'm gettin that I definatly need the new SAFC for my turbo to run well.....damn......almost saved 300 bux (cdn) Thanks for the replies guys, H-T FI Ownz
Old Jul 10, 2002 | 08:42 PM
Turbo Laser's Avatar
440 cc, 450 cc....from my years at dsmtalk.com I've seen both with regularity. There must be some years with 440 and others with 450, but the resources I go to don't always agree.
Old Jul 11, 2002 | 07:27 AM
legendboy's Avatar
Default Re: Will -30% work with DSM's ? (NOCARLOSER)
Bought New SAFC, $250 us.
ridnmyhonda
Apr 4, 2003 09:11 AM
rrei
Jan 27, 2003 10:27 AM
b18cya
Dec 20, 2002 05:48 PM
JeremyL
Dec 13, 2002 12:36 AM
freeplay
Sep 18, 2002 09:42 PM
