Car Won't Start after wire burned...HELP!!!
Old Apr 5, 2008 | 08:37 AM
Civic_07's Avatar
Default Car Won't Start after wire burned...HELP!!!
Okay this is the story...I was driving and this random wire under the passenger side of the car started burning ( it like burnt the carpet ). I think this cable was for like my subs or speakers but it didnt have no electric tape. So after it started burning i turned off my car...then next thing you know i tried to start it back up but it wont start?...however the headlights work. Did i blow a fuse?...starter fuse?...help plz
Old Apr 5, 2008 | 08:44 AM
Former User's Avatar
Default Re: Car Won't Start after wire burned...HELP!!! (Civic_07)
First disconnect the wire that was burning. Next, as you mentioned, check for blown fuses in the under-hood and -dash fuse/relay boxes.
Old Apr 5, 2008 | 09:09 AM
Civic_07's Avatar
yeah i checked if but there is no blown fuses...is there a diagram which you can show me where the starter fuse or relay is or something?...plz n thnx. I dont have a main relay switch diagram.
Old Apr 5, 2008 | 09:28 AM
Default Re: (Civic_07)
Help narrow the problem to the fuel or ignition system:
1) Do you hear the humming noise of the fuel pump for a few seconds when you turn the key to ON but don't crank the engine?
2) Is there spark at the plugs? Pull off a plug wire and insert a good plug in the end. Have a buddy crank the engine while you ground the plug threads to a convenient metallic engine part. You should see a bright spark at the tip of the plug. Repeat for each plug wire.
Old Apr 5, 2008 | 10:20 AM
Civic_07's Avatar
the thing is the engine wont even crank...
Old Apr 5, 2008 | 12:00 PM
Try recharging the battery. Also clean the battery terminals and connectors before hooking them up to the recharged battery. The O'Reilly in my neighborhood charges battery for free.
Where/how was the subs and speakers cable hooked into the car's electrical system?
Old Apr 5, 2008 | 12:21 PM
Civic_07's Avatar
iv already tried to get a boost, it the wires were connected it was just laying under my glovedepartments....it just heated up and burned the carpet...Im thinking the main relay blew?
Old Apr 5, 2008 | 12:35 PM
MrXclusivE's Avatar
is it cranking?
Old Apr 5, 2008 | 01:34 PM
The engine would crank even if the main relay were blown. Focus on the battery and its connections first.
If the battery is fine, then troubleshoot the starter. Inspect each of the starter wires and connectors. Also test whether the engine will crank by providing battery power directly to the starter. If not, the starter is likely bad.
Modified by RonJ@HT at 4:58 PM 4/5/2008
Old Apr 5, 2008 | 06:25 PM
Civic_07's Avatar
okay i checked the engine bay fuses...and the IG fuse ( Ignition Ground?) was blown, so i replaced that n it started up again. BTW i wrapped the two wires that touched with electric tape...But thank you all for your help
ca_db8
Sep 24, 2009 05:33 PM
SYNSEI
Jul 10, 2008 07:00 PM
FW_EJ8
Dec 17, 2007 06:03 PM
3M TA3
Sep 2, 2006 09:22 PM
i2atedie
Dec 2, 2004 04:46 PM
