Brake Light Stays On / AC Switch Not Working Properly
Old Apr 5, 2008 | 07:41 AM
R1blade75's Avatar
Default Brake Light Stays On / AC Switch Not Working Properly
Ok fellas, I tried searching for the answers, but I did not have much luck.
I just recently aquired a 97 Integra GSR and I ran into 2 problems.
1) The brake lights (LED Spoiler / BRAKE LIGHT) stays on even after the key is removed. I'm not sure if it has anything do to with the worthless aftermarket alarm (UNGO or somthing like that) that came witht he car.
2) The AC switch only works on level 3 and 4, meaning thers is cold AC. On level 1 and 2, only normal air blows out.
Can anyone chime in to the above problems?
Thanks!
Old Jul 13, 2013 | 10:36 PM
ddtriantos's Avatar
Default Re: Brake Light Stays On / AC Switch Not Working Properly
I am a new trial user, not sure if this is where I can ask a question. My question is: Because my three brake lights in my 1989 Honda Civic are staying lit even with my motor not running and my ignition key removed (I unscrewed the three light bulbs to keep the battery from discharging), does this mean the brake-light switch needs to be replaced?
Old Jul 13, 2013 | 10:37 PM
ddtriantos's Avatar
Old Jul 14, 2013 | 08:34 AM
fcm's Avatar
fcm
Old Fart
Brake light problem is most likely a broken stopper, there is a plastic "stopper" that the brake switch pin sits up against if it breaks and falls out of it's hole the pin has nothing to stop it from being "on".
A/C problem is most likely a bad blower resistor, blower must work for A/C to work, in your case reistors 1 and 2 are burnt out. 94
Old Jul 14, 2013 | 11:26 AM
aw614's Avatar
10 Year Member
Loved
for the brake lights
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/brake-lights-stay-how-i-fixed-them-2254546/
frustrated1965
Aug 18, 2024 10:00 AM
DC2-TEG
Dec 10, 2010 03:53 PM
cyclonedr
Oct 7, 2009 01:47 PM
LSracing94
Aug 30, 2007 09:29 AM
Sarren
Jul 14, 2004 12:32 PM
