way to fill rear mount?
okay so i'm filling all of my mounts with 3m window weld and i've gotten the front and passenger side done, drivers side will be cake, but my rear mount will be hell to get off, so i was wondering if anyone has found a way to fill the mount without taking it out of there? thanks, car is a 92 LS 5spd.
I also want to know the answer to this question. I already filled the bottom driver side mount, and the upper driver side mount. Its an EG2. But to you, efyou, Filling ALL the mounts might/will give you a hell of a lot of vibration. I've heard of people only filling only some particular mounts, and leaving the others OEM. The upper driver side mount I filled but I haven't installed since I have a new one there, and filled the old broken one to give it a try.
EDIT : I also used 3M window weld.
I have the energy suspension inserts in my em2 and it does vibrate, so wanted something more dd friendly for my ek. I ordered new oem mounts anyways, you think its a good idea to fill them? I figured wouldn't hurt, if anything it would make them last longer.
You can also fill the broken ones and its the same deal. I did that with my driver side top mount on my EG2, I had a new one filled the old one, installed, it, loved launching, HATED the vibration, so I replaced the new OEM one again. I have the bottom driver side one filled and also get slight vibration at idle. Anyways, never toss your old broken mounts, you can fill em as practice and try them out.
