dumb shift light question!!!
Old Apr 4, 2008 | 02:27 PM
dmotoguy's Avatar
Default dumb shift light question!!!
I'm electronically challenged..
can I wire a shift light (like the auto meter quick-lite) to my check engine light?
reason: I could adjust it in neptune rtp
bad: If I have a cel it would blind me!
Old Apr 4, 2008 | 02:44 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: dumb shift light question!!! (dmotoguy)
I've had this thought for a while as well. I need to check how much voltage is on each light to see if it will work.
Old Apr 4, 2008 | 03:26 PM
Turbo-charged's Avatar
Default Re: dumb shift light question!!! (2fast4u831)
yes it will work, but you should use a relay to power the light...im not sure if the stock signal is strong enough to power such a powerful light such as a shift light. mine is actually wired like that.
Old Apr 4, 2008 | 04:08 PM
jjspec's Avatar
Default Re: dumb shift light question!!! (Turbo-charged)
I have an autometer shift light (from a monster tach) and like Joe said, use a relay or you will burn a resistor in the ecu. Dont ask me how I know Works pretty good and it wont blind you. You may have to put the yellow cover on when it is dark though.
Old Apr 4, 2008 | 04:12 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: dumb shift light question!!! (jjspec)
what type of relay?
Old Apr 4, 2008 | 06:58 PM
jjspec's Avatar
Just a regular four pin relay. Let the ecu ground the control side and use the other side to power the shift light when the ecu grounds it. I think my relay came out of a 2002 Civic under hood fuse box. I had to have something in a hurry!
Old Apr 5, 2008 | 02:24 PM
rebo0t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">yes it will work, but you should use a relay to power the light...im not sure if the stock signal is strong enough to power such a powerful light such as a shift light. mine is actually wired like that.</TD></TR></TABLE>
x2
Old Aug 13, 2008 | 02:10 PM
dmotoguy's Avatar
Default Re: dumb shift light question!!! (rebo0t)
So a relay like this
Old Aug 13, 2008 | 02:49 PM
jjspec's Avatar
That will work.
Old Aug 13, 2008 | 04:25 PM
toyotaturbo's Avatar
see there's no such thing as a dumb question.
phazeone
Apr 19, 2007 07:34 AM
THC07
12
Jul 29, 2006 06:38 PM
ANVIL
May 15, 2004 08:14 AM
engineless
17
Jun 7, 2003 05:16 PM
arcboy
Jan 10, 2002 05:59 PM
