Engine Problem that i cant figure out, help please!
Old Apr 4, 2008 | 12:49 PM
blue89hatch's Avatar
Default Engine Problem that i cant figure out, help please!
well i recently swapped a d16z6 in my 89 civic hatch
on the interstate today it died on me. so i started it again while i was coasting and then i started hearing this rattling and clanking sound under the hood and my car started to over heat and run rough, then i lost complete power and it bogged down and died
I noticed the timing was off so i redid the timing and it started up but still a clanking sound and some rattling, so i checked the valve adjustment and it was all correct, and i looked at my timing again and somehow it managed to be way off again. im not sure whats goin on? or if maybe im about to throw a rod,
Any help would be appreciated alot! thank you
Modified by blue89hatch at 2:12 PM 4/4/2008
Old Apr 4, 2008 | 04:24 PM
alscrx's Avatar
Default Re: Engine Problem that i cant figure out, help please! (blue89hatch)
You don't have enough tension on the belt, adjust the tensioner pulley and spring!
Old Apr 4, 2008 | 09:44 PM
Default Re: Engine Problem that i cant figure out, help please! (alscrx)
the belt is plenty tense enough, i could get the belt barely on when the tensioner was loosened, then i tightened it, im just wondering if something siezed up like the water pump that would cause clanking and rattling? i cant figure out what that sound is, and i got the timing on it perfect again, and it hasnt adjusted again but i sitll have the clanking sound
Old Apr 4, 2008 | 09:57 PM
grog's Avatar
you could try disconnecting the upper radiator hose and turning the motor on (briefly) to see if the pump is working.
also the pump should be leaking out of the "bleed" holes if its bad or going bad
Old Apr 4, 2008 | 11:34 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Engine Problem that i cant figure out, help please! (grog)
you should drain your oil and look for metal too.. just for fun!!
Old Apr 5, 2008 | 05:05 AM
crx-si's Avatar
Did you check for holes in the block, sounds like you have more than and bad belt.
roc0487
20
Feb 20, 2013 12:20 PM
blue89hatch
Apr 5, 2008 01:11 AM
lmike6453
Mar 18, 2008 02:07 PM
onesloweg
Mar 28, 2007 02:41 AM
wez
11
Apr 16, 2006 02:55 PM
