cel help.................... plz
Old Apr 4, 2008 | 12:23 PM
2Point3's Avatar
Default cel help.................... plz
i just put my h23/vtec together and im getting cel 5,8,9,21. can anyone tell me what these are. 4th gen
Old Apr 4, 2008 | 12:37 PM
Giant_Bean's Avatar
Default Re: cel help.................... plz (2Point3)
5: Map sensor
8: TDC sensor
9: CYP sensor(both dist. related)
21:VTEC solenoid
Old Apr 4, 2008 | 12:44 PM
2Point3's Avatar
Default Re: cel help.................... plz (Giant_Bean)
would it be because im running h23 dist. instead oh h22????
Old Apr 4, 2008 | 12:52 PM
Giant_Bean's Avatar
nope, those are interchangeable. Is this a known good distributor, or an unknown?
Old Apr 4, 2008 | 01:01 PM
2Point3's Avatar
unknown, so if i replace the dist it would fix cel # 8,9
Old Apr 4, 2008 | 01:10 PM
Giant_Bean's Avatar
If you have an FSM, or a PDF copy on page 11-70 it walks you through a set of procedures to confirm that you have a bad distributor, or if you have access to a known good distributor, you can swap that one and check.
Old Apr 4, 2008 | 01:23 PM
2Point3's Avatar
well i started my car so does that mean i have a good dist.
Old Apr 4, 2008 | 01:36 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Point3 &raquo;</TD></TR><TR><TD CLASS="quote">well i started my car so does that mean i have a good dist.</TD></TR></TABLE>
More than likely, yes your distributor is good if your car is starting.
Something else is most likely causing those codes and replacing
the distributor will not fix the codes.
Giant_Bean's Avatar
not necessarily, the engine will run, but if one of the sensors is on it's way out, the ignition timing will probably not be where it should be, so it will run, just not the way it should. Just to cover all the bases you should probably double check the connectors and then do an ECU reset, and see if your code reoccurs.
Old Apr 4, 2008 | 07:38 PM
2Point3's Avatar
hey thanks for all the help guys i did a ecu reset and the codes went away.
kumar*
Aug 28, 2007 09:25 AM
minime-civic
Jun 5, 2007 03:04 AM
Fat Chick Magnet
Jul 30, 2006 09:06 AM
versatilezc
Jun 15, 2006 10:28 PM
EsQueue
Dec 31, 2003 04:26 PM
