B series swap (power steering ?)
Old Apr 4, 2008 | 09:31 AM
mister_ej2's Avatar
Default B series swap (power steering ?)
i have a 96 spec R in my 95 civic coupe and i am putting power steering on the car...just wondering if anyone else has done this and if so did the P/S line (line) up with the P/S pump where it connects (the fitting)....
and the end of the line does not look like it will go over the connector in the pump either....i am using a usdm gsr power steering pump....i also tried to put the line on a jdm b16 pump
i will try and get a pic of it later....i am probably not explaining it well but any advice would help....maybe i have to get the P/S line from a gsr so the fitting will work
Old Apr 4, 2008 | 09:33 AM
Blk00EJ8's Avatar
Default Re: B series swap (mister_ej2)
Use a Civic pump and a Civic pressure line and that should be that. I had my D-series pump on my B18.
Old Apr 4, 2008 | 09:39 AM
mister_ej2's Avatar
Default Re: B series swap (Blk00EJ8)
thanks....i think what it is is i am going to have to get an 92-95 sir power steering pump so the fitting is the same....
what brackets did you use??
Old Apr 4, 2008 | 12:29 PM
slacks's Avatar
bump! i want p/s and need to know the bracket too lol
Old Apr 4, 2008 | 12:35 PM
b16a3delsol's Avatar
Default Re: B series swap (slacks)
use b16 brackets. and i believe that b16 and gsrs sue the same power steering pumps too. i might be wrong though.
Old Apr 5, 2008 | 05:14 PM
the EM1 kid.'s Avatar
Default Re: B series swap (b16a3delsol)
brackets are good.....just the fittings on the line to the p/s pump....thats why i need a 92-95 jdm b16a pump...correct me if im wrong
Old Apr 5, 2008 | 06:17 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mister_ej2 &raquo;</TD></TR><TR><TD CLASS="quote">what brackets did you use??</TD></TR></TABLE>
I used the GSR bracket that came with the motor.
Mainsubject
14
May 4, 2013 03:34 PM
jdm 1080p
Sep 13, 2012 07:32 PM
b16ekinva
Oct 23, 2008 05:23 PM
Blk00EJ8
Jul 25, 2006 07:36 PM
kuelerz
Sep 24, 2002 10:16 AM
