EM1 engine mount
Old Apr 4, 2008 | 09:26 AM
DOHC4banger's Avatar
Default EM1 engine mount
my 99 si was hit and it broke the front left engine mount
my question is that do you have to take out the engine or can i just take it off and put a new one back on
ive never messed with the mounts before
Old Apr 4, 2008 | 09:34 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: EM1 engine mount (DOHC4banger)
All 3 engine mounts and both torque mounts can be removed/replaced w/o yanking the motor.
https://honda-tech.com/zerothread?id=339020
Remember to <FONT COLOR="red"><U>Search</U></FONT>
Old Apr 4, 2008 | 09:46 AM
Default Re: EM1 engine mount (mcvtec)
is there anything i need to worry about doing besides just taking the front left one off and putting it back on
Old Apr 4, 2008 | 09:50 AM
BryanM.'s Avatar
Resident Gearhead
Just to be 100% clear, which mount are you referring to? Driver's side or passenger side?
Either way, you are going to have to support the engine from the bottom. I usually use a jack and a piece of wood.
Old Apr 4, 2008 | 07:26 PM
its the driver side
and what would be the best spot to support the engine
Old Apr 6, 2008 | 08:08 PM
Old Apr 6, 2008 | 08:33 PM
EM1SiR85's Avatar
From: everywhere., cali,nevada,new york., united states
the strongest point of the oil pan is the best to support from the bottom
Old Apr 7, 2008 | 08:21 AM
Default Re: EM1 engine mount (EM1SiR85)
should i use a piece of wood or just put the jack right up on the oil pan
Old Apr 7, 2008 | 08:03 PM
bump
Old Apr 7, 2008 | 08:40 PM
slacks's Avatar
support it with a jack (if it's wide enough to cover a good part of a pan) or a jack and a piece of wood.
stands could work too but i tried that once and ended up working another transmission mount pretty good :[
edit... don't push the motor up.. just support it.
Old Apr 7, 2008 | 09:30 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: EM1 engine mount (slacks)
You dont need to support the engine. If you take off the big stupid fluid filled crappy always breaking top drivers side mount, there's still the AC mount holding the motor onto the car.
Take off mount. Put on new mount. Done. You dont even have to lift the car off the ground.
Old Apr 8, 2008 | 08:40 AM
Default Re: EM1 engine mount (B serious)
thats what i originally thought
they told me the mount was broken on the inside of it
Old Apr 8, 2008 | 09:36 AM
B serious's Avatar
if you're just taking off any ONE mount, you really dont need to support the engine. 2 or more mounts, and you need to support the engine with something. I use a book and a jack with a big pad underneath the oil pan. The part that portrudes.
Old Apr 8, 2008 | 10:11 PM
ok thanks
SilverWarrior
10
Apr 3, 2018 08:16 AM
sealz
Acura TSX
Mar 15, 2008 10:21 PM
bopbop93030
Jan 31, 2008 06:39 PM
Civic168
Suspension & Brakes
Feb 28, 2006 09:21 PM
SkylineGTR
Apr 6, 2005 10:33 AM
