Best way to Remove a glob of bondo in the gas cap hole?
Old Apr 4, 2008 | 01:28 AM
AGP-EG's Avatar
Default Best way to Remove a glob of bondo in the gas cap hole?
Someone before me was doing a gas fillup relocation i guess you could call it, so they filled in the hole where you put the gas pump in, where the little gas cap door is basically with bondo.
Right now it's cruddy, needs to be sanded down, but i much rather remove it somehow and return it to original design so i don't have to keep filling gas in the back so it doesn't smell like gas fumes inside the car on occasion.
Whats the best way to remove a solid chunk in the square hole like this of the gas cap area safely and effectively without scratching the body up.
Tool's/chemicals and tips/suggestions needed, thanks.
Old Apr 4, 2008 | 06:37 AM
luvtositdumpt's Avatar
From: somewhere in the d, mmm stake, mmm country fried stake
its just bondo right?...hammer and chisel maybe...?
Old Apr 4, 2008 | 07:58 AM
AGP-EG's Avatar
well i never takin bondo off before so i don't wanna accidently chisel into the metal and dent it or [freak] up the paint underneath that crap.
Old Apr 4, 2008 | 10:21 AM
most likely the paint under it is already freaked up...if all they used was bondo then it would be like a cube of bondo where the gas filler used to be....id say just tap it out...not hard tho...u kno light tapping...
Old Apr 4, 2008 | 03:51 PM
AGP-EG's Avatar
ah, yah but it seems it's kinda pasted around the outside of the gas cap hole area on the edges, apparently this is gonna take a long time to carefully chisel and crack around.
Old Apr 4, 2008 | 04:14 PM
onelovebiker's Avatar
i agree, light tapping with a BFH (big [freak]ing hammer).lol jp, most likely ull have to sand down n repaint tha area. so just take ur time be aware of how deep your chisel is digging..
Old Apr 4, 2008 | 06:38 PM
AGP-EG's Avatar
yah i'll go slow about it, just didn't wanna use a heat gun or torch since there fumes around the area, but this **** looks caked on there.
Old Apr 6, 2008 | 09:40 PM
Hawkze_2.3's Avatar
Default Re: (AGP-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGP-EG &raquo;</TD></TR><TR><TD CLASS="quote">yah i'll go slow about it, just didn't wanna use a heat gun or torch since there fumes around the area, but this **** looks caked on there.</TD></TR></TABLE>
Rent or borrow a power sander for sure! You will damage the paint around the hole, no way around it really. I think I'd use a small flathead screwdriver and lightly chisel away the filler material as far to the sides as you can, then sand off the rest.
Old Apr 7, 2008 | 12:27 AM
alltech.magoo's Avatar
i agree with using a chisel and hammer it out little by little with caution.
keep us posted
Old Apr 7, 2008 | 12:28 AM
AGP-EG's Avatar
Sure will guys, thanks again for tips!.
Old Apr 7, 2008 | 07:39 AM
goldex420's Avatar
paint stripper and a heat gun and a scraper
put the paint stripper on "aircraft striper" or somethin like that. well put that on and heat gun it and it should boil off.
Old Apr 7, 2008 | 05:56 PM
DA_teg04's Avatar
Default Re: (goldex420)
5" high speed grinder with a 40 grit sanding disc then chisel or hand sand whats left
Old Apr 7, 2008 | 06:38 PM
JDcompman's Avatar
Default Re: Best way to Remove a glob of bondo in the gas cap hole? (AGP-EG)
Put on a facemask and eye protection and have at it with a wire wheel. You won't damage the paint and the wirewheel will do a great job of removing the bondo.
sde780
Feb 9, 2011 04:07 AM
TouringAccord
12
Jun 21, 2004 08:02 AM
GUNNER666
Mar 28, 2004 05:14 PM
civicracer1993
Jul 7, 2002 08:11 AM
