FS: Snow Performance Methanol Injection kit
Old Apr 3, 2008 | 04:01 PM
Outkast95LS's Avatar
Default FS: Snow Performance Methanol Injection kit
"This kit uses manifold boost pressure to determine when and how much fluid to inject. Proportionally injecting according to boost pressure gives the most accurate delivery of water-methanol and allows the most cooling and performance improvement over the widest range. More power and driveability is the result. It can be used on any forced induction engine: carbureted, fuel injected, turbocharged, positive displacement or centrifugal blowers. The most suitable are the centrifugal supercharged and turbocharged engines, as they build boost is a more progressive manner concerning water-methanol injection. The positive displacement blower
engines will work, but it might take more work to dial in the delivery. For higher boost applications (over 25psi), the controller can be upgraded to our VC100 unit. Now with Lifetime Warranty - please see details."
Selling a USED Snow Performance Methanol Injection kit. Bought it used, but never put it to use myself. Perfect for street cars that want MAJOR power. I was going to use it on my Integra but I'm low on funds and need the cash.
Retails for over 400 bucks.
Looking to get 250 bucks PICKED UP.
Will also include a 3 gallon drum of 100% Methanol (if you do 50/50 mix, it'll be a 6 gallon mixture)
I'll post up pics of the actual kit when I get home.
Old Apr 3, 2008 | 04:02 PM
LowTEC-Derbo's Avatar
Old Apr 3, 2008 | 04:32 PM
sfgreddiedsi's Avatar
up for the chigga
Old Apr 3, 2008 | 04:53 PM
brand0's Avatar
Default Re: (sfgreddiedsi)
Old Apr 3, 2008 | 09:32 PM
rebo0t's Avatar
Any of you guys who is boosting, this is for you. Water/meth injection is great when you have it setup correctly. Even if you dont want to raise your boost with the kit, at least use it for safety incase you run a bad tank of gas.
Old Apr 3, 2008 | 09:42 PM
SjCiViCHB's Avatar
Default Re: (rebo0t)
Old Apr 4, 2008 | 06:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebo0t &raquo;</TD></TR><TR><TD CLASS="quote">Any of you guys who is boosting, this is for you. Water/meth injection is great when you have it setup correctly. Even if you dont want to raise your boost with the kit, at least use it for safety incase you run a bad tank of gas. </TD></TR></TABLE>
Old Apr 5, 2008 | 05:46 PM
Default Re: (Outkast95LS)
bump
Old Apr 8, 2008 | 12:36 AM
bump
Old Apr 8, 2008 | 12:30 PM
up
edogg6565
Mar 18, 2011 06:23 AM
integlspwr2k
Aug 3, 2007 01:56 PM
CeeJayy
Mar 5, 2007 07:29 PM
7rrivera7
Nov 19, 2002 05:50 AM
