v-tec qiuts working????? W.T.F
Old Apr 3, 2008 | 01:32 PM
egcoupeSI's Avatar
Default v-tec qiuts working????? W.T.F
v-tec will engauge 2 times but then gives out. first it was throwing the pressure switch code, so I jumped the wire to the v-tec wire. code went away but Im still having the same problem. First It'll engauge at the proper RPM, then it will engauge about 500 RPM higher, then it wont engauge at all. any suggestions will help!
Old Apr 4, 2008 | 01:44 PM
1fastlude1's Avatar
Default Re: v-tec qiuts working????? W.T.F (egcoupeSI)
check your oil and oil pressure
Old Apr 9, 2008 | 07:47 AM
egcoupeSI's Avatar
Default Re: v-tec qiuts working????? W.T.F (1fastlude1)
Ive changed my oil sevral times, My oil level is perfect. could It be my soliniod going bad? HELP!! My oil pressure is perfect. had I checked at a dealership today.
Old Apr 9, 2008 | 12:44 PM
Acidcrakker's Avatar
It can only be two things now.
1. YOur Solenoid is bad
2. Your ECU is not sending a signal
Okay 3 things
3. Your Vtec Oil pressure housing needs to be cleaned out.
Old Apr 9, 2008 | 03:05 PM
egcoupeSI's Avatar
Default Re: v-tec quits working????? W.T.F (Acidcrakker)
v-tec housing cleaned out! ecu is sending signal! I guess the only issue left is the soliniod. ANYBODY GOT 1 FOR SALE??????? HELP!
Old Apr 15, 2008 | 11:59 AM
egcoupeSI's Avatar
Default Re: v-tec quits working????? W.T.F (egcoupeSI)
ok, so I bought a new soliniod........ STILL HAVING THE SAME PROBLEM..... any sugestions will help!!!
Old Apr 15, 2008 | 04:16 PM
egcoupeSI's Avatar
bump... any 1
Old Apr 17, 2008 | 08:47 AM
egcoupeSI's Avatar
never mind ladies and gentleman.... my car got stolen last night. 4-16-08.
R.I.P
95 civic ex coupe
99 B16a2
crower dual valve springs
crower titanium retainers
crower flat top valves
ARP head studs
JDM P30 pistons
head milled .010
cometic 2 layer head gasket
skunk 2 cam gears
DC tri y headres
Greddy evo 2 exhaust
act 6 puck ceramic clutch & pressure plate
16 in rota slipstreams in Bronze
AEM big brake kit with cross drilled and slotted rotors
94wip
12
Jun 20, 2024 07:23 PM
NVMYDC
Aug 10, 2009 02:14 PM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
cioli
Jul 31, 2005 12:24 PM
allnapower
Apr 1, 2005 08:22 AM
