help on type s tranny oil
Old Apr 2, 2008 | 05:51 PM
josedc5s's Avatar
Default help on type s tranny oil
how many quarts do i need in my 2006 rsx type s tranny
Old Apr 2, 2008 | 06:07 PM
dan12288's Avatar
Default Re: help on type s tranny oil (josedc5s)
Old Apr 3, 2008 | 05:25 AM
blueshark123's Avatar
Default Re: help on type s tranny oil (dan12288)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan12288 &raquo;</TD></TR><TR><TD CLASS="quote">3</TD></TR></TABLE>
No....
1.6 qt for fluid change
1.8 qt for overhaul
So if you arent taking the tranny apart and just changing the oil it's 1.6
Old Apr 3, 2008 | 06:02 AM
chargeR's Avatar
Default Re: help on type s tranny oil (blueshark123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueshark123 &raquo;</TD></TR><TR><TD CLASS="quote">
No....
1.8 qt for overhaul
So if you arent taking the tranny apart and just changing the oil it's 1.6</TD></TR></TABLE>
Truth. Do not trust that other guy. Buy 2 quarts and fill it until it overflows.
Old Apr 3, 2008 | 02:16 PM
k20typeR24's Avatar
Default Re: help on type s tranny oil (chargeR)
i work at acura and blue shark is right DO NOT FILL TILL IT OVERFILLS!!
Old Apr 3, 2008 | 02:47 PM
dan12288's Avatar
Default Re: help on type s tranny oil (k20typeR24)
what i just did my tranny changed and they sold me 3 quarts and my local acura dealer... took it to my uncles shop and it took two and a little from the 3rd... this is for the rsx-s 04... so i dont know what you guys are talking about? and to add it stoped the 3rd gear grinding issue.
Old Apr 3, 2008 | 02:56 PM
NiPBoi's Avatar
weird, i just did mine last week and just barely got 1 and half qts in. Mine is an 05 tho.
chargeR's Avatar
Why not fill it until it overflows? When parked on level ground the fill bolt hole is at the right height so that the fluid should be level with it when the transmission has the right amount in it.
Old Apr 3, 2008 | 03:50 PM
k20typeR24's Avatar
actually i think you are right the fill hole is at the right level sorry about that
Old Apr 3, 2008 | 03:52 PM
k20typeR24's Avatar
Default Re: help on type s tranny oil (NiPBoi)
nipboi did you change the tranny filter is your auto or stick
Old Apr 3, 2008 | 06:10 PM
dan12288's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiPBoi &raquo;</TD></TR><TR><TD CLASS="quote">weird, i just did mine last week and just barely got 1 and half qts in. Mine is an 05 tho.</TD></TR></TABLE>
did you flush out the old fluid out? i did and it took the two quarts and some from the 3rd (about 3/4).
Old Apr 3, 2008 | 06:12 PM
dan12288's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chargeR &raquo;</TD></TR><TR><TD CLASS="quote">Why not fill it until it overflows? When parked on level ground the fill bolt hole is at the right height so that the fluid should be level with it when the transmission has the right amount in it.</TD></TR></TABLE>
you are correct fill untill it leaks out.. but car must be parallel to the ground.
Old Apr 3, 2008 | 06:41 PM
chargeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20typeR24 &raquo;</TD></TR><TR><TD CLASS="quote">actually i think you are right the fill hole is at the right level sorry about that</TD></TR></TABLE>
All good . Just wanted to make sure that the right information is out there.
hammergunner
Sep 11, 2008 08:00 PM
accord03coupe
Honda S2000
Apr 8, 2008 06:41 PM
92hondalude
Jan 10, 2005 11:19 PM
99cxrico
15
Aug 13, 2004 05:36 AM
jmk2888
Jul 7, 2004 09:51 PM
